How are the MMM with buildup?
/ How are the MMM with buildup? #1
Haywire
Veteran Member
Central Kentucky
Tractorless :(
Got my 2660 in December, and am looking forward to spring and the grass cutting season. My old JD LT-180 required hosing out after every other cut (~2 acres each).
How do the Kubota decks fare when it comes to clippings building up under the deck?
Ian
/ How are the MMM with buildup? #2
I don't get any buildup to speak of. Maybe a quart scraped off when I change out the dull blades.
Depends on how wet the grass is, and what other type mowing you do - more than the deck IMO :)
If your previous deck required cleaning, then your new deck will likely require the same. ;)
/ How are the MMM with buildup? #3
Ian
Ian, Since you bought a belly mower YUCK!!!!!!!
Buy some "Mow Deck" spray to make the deck
non stick and just save your money and buy a
small rear mount flail mower from Ken Sweet.
/ How are the MMM with buildup? #4
I do not think any deck will be immune from buildup. Spray with vegtable oil, teflon spray, or add deck wash nozzels.
Washing mid mount deck in pond while attached to tractor is not advised as others have tried as the tractor sinks fast.
David Kb7uns
/ How are the MMM with buildup? #5
We didn't clean ours out at all this year nor did we spray it. There is minimal buildup.
/ How are the MMM with buildup? #6
Don't mow when it's wet? Seems to be the cure for any mower I've owned, mid, rear, or otherwise.
/ How are the MMM with buildup? #8
There is moisture in the grass even if you are careful to mow in dry conditions. I clean mine 2 to 3 times a season.
/ How are the MMM with buildup? #9
Leonz: I know you always push the flail mower. Which flail mower do you own?
I priced a 60" flail mower... Yeesh! Over $2K. Not this fellow. A tiller is much higher on the list and for less money.
/ How are the MMM with buildup? #11
Ian
hmm you mean compare kubota MMM to the el cheapos tractors? I really dont think there is a difference. Maybe a little- Some cheapo tractors dont have much buildup, others have so much buildup due to shape designed. I would have to say that kubota MMM is on the better side. You still need to scrape it in couple spots, but other wise its pretty good.
/ How are the MMM with buildup? #13
Mathews Company Lawn Genie 48" 16 H.P. Briggs and Stratton I/C with a cast iron piston sleeve- they do not make these mowers or engines any more and its a shame too.
I can still get engine parts which is nice as I would have to buy a Briggs Vanguard twin to replace it.
/ How are the MMM with buildup? #15
I only clean once a year in the fall, not much to remove. Says it all!
/ How are the MMM with buildup? #16
same here not much hangs in there,when I mow when its real wet it will stick but comes right uot the next time I mow. When I remove it in the fall always do a real good cleaning while its sitting on tthe stand wheels.
/ How are the MMM with buildup? #17
Sounds interesting. Show pictures please.
/ How are the MMM with buildup? #18
I do get a fair amount of buildup, but it doesn't affect performance all that much. I just scrape it off once a year when I remove and sharpen the blades.
/ How are the MMM with buildup? #20
I've used my BX2660 for two seasons with the MMM. I only had lots of buildup once and that was after mowing very wet grass. Otherwise its never been a problem mowing less than 2 acres.
2015 KENWORTH T800 TRI-AXLE (A65643)
2015 KENWORTH T800...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
7' Barnwood Bar Table (A66408)
7' Barnwood Bar...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
1997 Dodge Ram 3500 Dually Truck, VIN # 3B7MC33D5VM559525 (A65563)
1997 Dodge Ram...
