Houston we have another problem.
/ Houston we have another problem. #21
Great point. I think what happened is there's a chain on the rototiller that is connected to the plastic protective sheath that goes around the PTO shaft. I clipped the one end on to the pin that holds the lift arm, which must have put pressure on it and caused the pin to break, thus causing the lift arm to fall, and sheer the filler neck.
Don't those Deeres have a hole on the pto guard?
Probably...is that where it's supposed to go...I'll look (stupid me;))
/ Houston we have another problem. #23
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
Dickson Ind. 4080 SX Turbo Blast Asphalt Surface Prep Machine (A64194)
Dickson Ind. 4080...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
IH 1486 Tractor (A66285)
IH 1486 Tractor...
