House Power OUT/ON indicator of some kind?
   / House Power OUT/ON indicator of some kind? #11
Having an alarm screaming for the entire outage would be extremely annoying. Maybe a light instead?
   / House Power OUT/ON indicator of some kind? #12
It doesn't. It's normally powered off when you have line power, i.e. no power outage. When the power goes out you turn the device on but it's silent, once the wire you've wrapped around the main incoming line senses line power then it starts screaming.
   / House Power OUT/ON indicator of some kind? #13
I would just put a couple of neon pilot lights on each leg of the feed. You only need one but two would tell you if you have only half service. When the utility power is hot, you get glowing lights. It would require looking once in a while but at least no screaming alarm.
   / House Power OUT/ON indicator of some kind? #14
My ONLY comment to the OP is, I hope you are totally breaking out your utility feed when you power up your genny. If not, you are backfeeding the utility and if there is a lineman working on a pole near you, you could very well electrocute him. The transformer on the pole drops your feed down to 220 or 110-1 but when you backfeed the can, it steps up your voltage to whatever the line feed voltage is. Bad business.
Just break down and buy a vacuum break transfer switch and wire it in. No all the expensive to begin with.
   / House Power OUT/ON indicator of some kind? #15
How is it possible to backfeed when your main breaker is off ?
   / House Power OUT/ON indicator of some kind? #16
If your meter is in a location convenient to check, and it happens to be a digital model, you'll notice there's a "240V" indicator that comes on when power is restored. Since meter is upstream of your transfer switch and main breaker, this is always live.
I had the same problem as you, until I noticed this "feature". Now I just stick my head out the front door every 30 minutes or so, to see if the meter has lit back up.
   / House Power OUT/ON indicator of some kind? #17
I used one of those on my panel with one of those breaker interlocks before I installed a whole house generac and transfer switch. It worked but,not reliably. I found the part you wrapped around the incoming line would pick up/sense the voltage from the generator power in the panel.
I'm not advising you try it but my solution was to wrap that area area of the pickup with a small piece of aluminum flashing which I grounded to the ground bar. Then I wrapped that with some rubber to make sort of a Faraday cage so it could only pick up/sense voltage in the utility line when it came back on.
   / House Power OUT/ON indicator of some kind? #18
Have a cabin not far from the log house on the same phase. Can see when the power is restored from our house.
The utility company has a pretty good outage map on their website. Sometimes can tell if power is going out for 10minutes or 10hours.
New digital power company meters do have a little light.
Use to have frequent power outages because we were out in the sticks. Population grew, grid upgraded and rarely had an outage for over 30years. After Covid the population exploded and back to frequent outages.
   / House Power OUT/ON indicator of some kind? #19
I don't know if I have one of those meters or not. Even if I did, I can't see it from the house. The meter is on the opposite side of the pole and about 300' away. 🤷‍♂️
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
207276 (A52708)
207276 (A52708)
2003 Big Tex 10PI...
Freightliner Tender Truck - Adams Tender (A56436)
Freightliner...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
