Harry in Ky
Elite Member
Has anyone(or anyone you know) purchased one of these "add on" or "conversion" power steering kits? If so, what kind of success did you have with it? Did it come with any instructions, parts I.D. or any paperwork?
Ford / New Holland Power Steering Conversion Kit 2 3 36 361 4 | eBay
A friend recently ordered one similar to this billed as "FD100 kit" from Amazon, and promptly enlisted me to help him install it. I see a dozen or so similar units listed for sale by various suppliers. They all seem to be pretty much the same other than some come with more parts than others.
I've been looking for some information concerning the cylinder/valve unit. We're trying to install the unit in place of an original factory unit on his 4000 three cylinder. So far with absolutely no success. It fits in place of the original, with some slight modifications but it just doesn't seem to work. With the engine off, moving the steering wheel causes the control valve to operate as the old one does, more or less as I would think it should, cancelling back to neutral when the wheel is released. Problem is when the engine is running and the wheel is turned it opens the valve and the cylinder just takes off jerking the steering wheel out of your hands, turning the tires against the stops, and loading the pump against relief. No amount of effort applied to the steering wheel will cancel the pressure until the engine is turned off.
So far the seller has been of no help. With the number of kits, sellers, and most likely buyers out there, surely SOMEONE must have a report on having installed one, along with a review on how it all worked out.
