House Construction - Best Value Dimensions
/ House Construction - Best Value Dimensions #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
Getting close to finalizing building plans for a home we are building on some vacation/retirement property we have owned for several years. I have asked allot of questions on this and other forums and am always grateful for the shared knowledge. Before I ask the designer to finalize our floor plans into engineering drawings I would like a sanity check.
Exterior dimensions will be 28' W and 35' L, we can go no smaller and still keep the interior dimensions like we want. Understanding that sheathing is 4'x8' my thought is to increase the length to 36' and that would basically be free space. We are down-sizing and do not want a large home but if it would make sense to add a couple more feet for minimal cost why not? Your thoughts appreciated.
/ House Construction - Best Value Dimensions #2
I'd say that even with the best planning, there will be more scrap than you'd like. Studs may nor be uniformly spaced in places due to support requirements, windows, doors, etc. that will in turn dictate how some of the sheathing is cut and used.
When really trying to maximize material usage and minimize waste, start planning from the roof down. If you have gable and eave overhangs, factor that in as well.
Having just built a house, I'd say there are so many factors to juggle, you might want to take a shot a making efficient use of materials, but don't feel bad if you have to let it slide. There are already a bunch of other things to deal with!
Good luck!
/ House Construction - Best Value Dimensions #3
if you are looking to eliminate waste and reduce cost start inside be sure all rooms and walls utilize full sheets and let the exterior perimeter be the odd size
This will help with flooring costs too.
/ House Construction - Best Value Dimensions #4
I always hate tossing 12" of floor joist or a 12" strip of plywood into trash so I am with you. Some siding material falls into this category as well.
Plaster board is cheap so that is no brainer. Plumbing and elect always uses up bits so that's no concern.
When you consider it adding 1 foot to a wall is merely 1 stud more.
Where you really can save is in the floor plan.
The more checks and nooks the costlier to build as corners eat up studs and roofing gets complicated. Foundation guys charge extra for each corner while straight runs are merely by the foot.
Then later comes maintenance. A roof with lots of hips and valleys will deteriorate faster as there will be poorer circulation and cost more to repair.
While not as pretty, a square box shape with even dimensions will be the lowest cost to build.
You selected 28' as one dimension which is good as that is twice 14 which is a OK for 2 x 10's while over would call for 2 x 12's.
Sideing is generally not an issue even though it generally is in 12' lengths as widows and doors rapidly chop the runs into usable lengths with minimal trash left over.
I'd for sure encourage you to round out the dimension to 36 ft as that last foot will be painless.
By the same token, roofing is also interesting to consider.
Sometimes more overhang only costs a few shingles as it saves cutting off decking and creating scrap (ie 24" vs 16" overhang.) The more overhang the better protected the sideing.
One area I encourage to spend more on is the roof. Here I like to cover the entire roof with self adhesive self sealing membrane before laying shingles. In fact a trend is to lay better membrane and cheaper shingles as the membrane is really your leak protection while the shingles provide UV protection to the membrane. Also most membranes are 'self healing' in that heat softens them to the point that they self cure and actually plug up nail holes etc.
/ House Construction - Best Value Dimensions #5
You can not justify using all the material in a few sheets of plywood as a cost effective means of sizing a home. The bigger it is the more everything else involved costs. If you cut 2 feet off a sheet and think it's wasted money, figure out how much that 2 feet of plywood costs to put a foundation under,frame, side,insulate,electrify,roof,etc. It's a snowball. Build what you want and let the chips fall where they may.
/ House Construction - Best Value Dimensions #6
The shell is the cheapest part of the house. Fixtures and finish is where the money goes, particularly in the kitchen. If you add the square footage to bedrooms, it will be cheap. If you add it to the kitchen or bathrooms, not so much.
/ House Construction - Best Value Dimensions #7
35' long is odd measurement when calculating rafter spacing @ 2' OC & stud and joist spacing @ 16' OC. Sheating is small fraction of the cost and at 35' likely to have more waste. Adding the extra foot will not require another rafter, floor or ceiling joist. Only extra cost will be in foundation and roofing if shingled and that would only be a couple bundles.
/ House Construction - Best Value Dimensions #8
This is very true, although there is one more thing to consider. A wise old man told me that on any job, the highest costs walk on two legs. Labor is going to be the biggest single item in a build. The simpler the design, the less it is going to cost. But, before you jump on that, think about whether you want to live in a low-cost box or do you want a home with more visual appeal?
/ House Construction - Best Value Dimensions #9
A builder friend has done real well building spec homes the last 45 years... when he was starting out... his homes offered the most square feet for the money because they were basically cubes...
Irish Tom is his name and he never finished 8th grade... came here with nothing and made a good life knowing how to build... his homes today are in the 2 million range.
Anyway, he explained it as follows and he was also a stickler for using everything he paid for... no wasting a foot from a floor joist or cutting plywood panels...
Example:
a 40 x 40 home has 160 lf of walls and provides 1600 square feet of home.
a 30 x 50 home also has 160 lf of walls and provides only 1500 square feet home...
Tom is the smartest guy I know without a formal education... he always told not having money to waste makes you efficient!
Thanks everyone, good points. No free rides
Labor is what has delayed building for 5 years. Our initial plan was a turn key house but getting half a million in debt 5 years before planned retirement made us rethink allot of things. Downsizing square footage, simplified construction and many discussions with contractors and building inspectors have led to the decision to have the foundation poured and house dried in by sub-contractors and do most of the interior work including electrical and plumbing as time and money permit. The real work was finding out how the county building inspectors will let me function as the GM for this project. Current trends born by the states desire to weed out developers who purposely defraud buyers by going out of business after building 100 houses leaving the buyers hanging have made it almost impossible to for an individual to build their own house.
As far as curb appeal this house will be on 8-acres, 100 yards from the fence on a dead-end road and I am hoping it doesn't draw any interest to those out looking for a place to rob. Comfortable inside and boring outside is the goal.
Example:
Thanks for the math review, I had forgotten that anomaly of area of a square, surprised Tom didn't build round houses :laughing:
/ House Construction - Best Value Dimensions #11
No round houses... some of his more current homes have turrets...
Different market and different times...
He has a lot of simple truths that I love... drives an old pickup and you would never know he builds on his own dime... never takes out a construction loan.
A little off topic... Tom would say how can the government be broke when a dollar changes hands a couple of times the government gets it back... speaking about 10% sales tax and 50% state and federal California taxes...
/ House Construction - Best Value Dimensions #13
I think small buildings like cabins are more affected by poor choices of building dimensions and not taking into account material sizes.
My personal choice is for a shed roof style, oriented facade south, roof sloping down to the north, earth berm around the West and North. Southern roof overhang to prevent summer overheating. I'm going small on the house and big on the barn, built in a similar style...
/ House Construction - Best Value Dimensions #14
Building a house that you may retire in might lead one to think about handicap access. Building a house with hallways and doors wide enough for a wheelchair or walker is something to think about. A 4' hallway might make for 14' rooms which may or may not be small. Ramps or low stair count to get into the office is another factor. My wife is figuring out where a ramp can be built and we are in our mid fifties.
/ House Construction - Best Value Dimensions #15
Best to keep the overall foot print on 4' increments as that will insure the best use of material.
Consider a gambrel roof as the additional space can provide storage or perhaps future living space. For sure build over a basement as that will be the cheapest space in the residence.
If your planning to occupy the building before it's finished and doing the interior your self be sure to get the blessing of the local building official and banker.
/ House Construction - Best Value Dimensions #16
I am in total agreement. I designed our house as our retirement home, and there is a ramp inside the garage, which provides easy access to the interior level. Before we moved to the country, we lived in suburban CA and it seemed like 10-20% of the houses in the nicer, older subdivisions had a ramp added to the house. This always looked unsightly because the house was not designed for it, and if anyone ever had to use the ramp it left them at the mercy of the weather. A ramp inside the garage is easy at the design stage, and is always out of the weather.
Every door is a 36" door. The maser bath is designed with room for both a wheelchair and an attendant.
We don't need any of these features right now, but if, God forbid, we need them in the future they are there and waiting for us. Adding them afterwards will cost many times what designing them in ahead of time costs, and the need will be at a time of great stress, not a good time to be evaluating contractors. And, the money comes back when the house is sold. Handicap accessible is a feature that adds to sales price. Kludged-on additions detract from sales price.
/ House Construction - Best Value Dimensions #17
Having lived this for the past couple years, I can tell you there is no easy solution. You cannot maintain all building materials in 4' or 8' increments no matter how hard you try as every piece of the structure has it's own quirks. If you make the foundation 4' increments, the framing will not be, as it is not set to the same exact points as the foundation (sheathing typically overhangs foundation, for example). Plus the inside and outside of the foundation will not both be on 4' increments, for example. By the time you get ready for siding, you will have added another couple inches to the dimension, so it will hit you again. Similar with roof sheathing. The one I think I would try to hit is exterior sheathing. Let the foundation guys match up to it as they can add in odd sized forms to make up the difference at a corner. You will really hate it if you have to stretch a 4x8' sheathing sheet by 1" to make it to the corner... Cutting off 1" is not as bad, but does take extra time.
Some things are already out there to make your life easier. Precut studs are a biggie. Design to use them for 8', 9' or 10' walls, and that will save a ton of cutting.
/ House Construction - Best Value Dimensions #18
If your handy and comfortable with tools a big barn will save money on the house. I'm sure the OP gets rain in Georgia. Having an empty place to store all the building materials and storing "leftovers" keeps the quality of construction materials high.
One of the features that "sold" us on our retirement house was wide doorways and halls. It's so nice to be able to move furniture around easily. I just constantly have to make sure SWMBO doesn't put up a small shelf unit or such in the hallway.
Another feature to not overlook is "higher" than the 8' average ceilings. Especially if you are tall.
/ House Construction - Best Value Dimensions #19
I would rethink the boring outside idea. Think resale. At some point, someone will have to sell the house and a little bit of design work that costs a little bit of money can go along way. I see some many houses that are a rectangular box that look like scat. If they had put in a few usable details like a porch or added a small roof that sheds water away from the door(s), it really makes a house look good.
A higher roof line, say a 6/12 vs a 3/12 or 4/12, not only sheds water, snow, and ice more efficiently, the roof looks better, minimizes leak risks, and can give better head room access in the attic. If you have a south facing roof, getting the proper angle for your location is critical if you every install solar water heating or solar power panels.
We built our dream home in the country and it looks good even though nobody but us can see it. That may change in the future. We thought we would live in this house until we died or had to go into a nursing home but we are thinking of selling everything to buy a boat and see the world before we get old. I never would have guessed we would seriously consider the boat idea but here we are thinking about selling everything. Don't lock yourself into a plain design. Think resale.
Later,
Dan
/ House Construction - Best Value Dimensions #20
Later,
Dan
My friends did that... bought a steel hull 3 masted schooner and sailed the world for 5 years... it was everything they wanted and more... they had a deep water dock in their backyard so it wasn't as if they were gone 5 years straight.
They sold the Bay Area home, the boat and the Cessna P210 and bought 20 acres on a trout stream in the mountains and now have a barn and Deere 110tlb.
I love to hear when a plan comes together... they are both around 70 now and enjoy the country life... who would have thought...
The barn they built was laid out to minimize any waste of material... a little forethought makes a big difference.
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
New/Unused Electric Golf Cart (A61166)
New/Unused...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
1999 Jaguar XK8 Convertible (A61569)
1999 Jaguar XK8...
2025 SDLANCH SDLC1220 High End Carport (A60352)
2025 SDLANCH...
2014 CASE 105C (A62177)
2014 CASE 105C...
