Hour meter, headlights and horn not working on Kubota B7100
   / Hour meter, headlights and horn not working on Kubota B7100 #1
BalfourGirl
Balfour BC Canada
Kubota B7100D
I've checked the fuses, emergency lights work, the tractor starts, but I can't figure out what to do about the hour meter, headlights and horn. Ideas?
   / Hour meter, headlights and horn not working on Kubota B7100 #2
That sounds like a corroded ground connection, broken ground wire, etc. I would look under the dash for a ground wire that runs to the tractor frame, and take a hard look at it.
Hope that helps.
Thanks Thomas... I'll check that!
   / Hour meter, headlights and horn not working on Kubota B7100 #4
I have the same tractor and I had the same problems and mine was the fuse linkage gone bad. The hour meter, headlights and horn get power from the same fuse.
2007 PETERBILT  385 CAB AND CHASSIS (A50854)
2007 PETERBILT...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A51039)
2014 Yale 3 stage...
1996 Eager Beaver 44ft. 50 Ton Tri-Axle RGN Lowboy Trailer (A49461)
1996 Eager Beaver...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A49461)
2022 Ford F-250 XL...
