Hour meter, headlights and horn not working on Kubota B7100
   / Hour meter, headlights and horn not working on Kubota B7100 #1
BalfourGirl
Balfour BC Canada
Kubota B7100D
I've checked the fuses, emergency lights work, the tractor starts, but I can't figure out what to do about the hour meter, headlights and horn. Ideas?
   / Hour meter, headlights and horn not working on Kubota B7100 #2
That sounds like a corroded ground connection, broken ground wire, etc. I would look under the dash for a ground wire that runs to the tractor frame, and take a hard look at it.
Hope that helps.
Thanks Thomas... I'll check that!
   / Hour meter, headlights and horn not working on Kubota B7100 #4
I have the same tractor and I had the same problems and mine was the fuse linkage gone bad. The hour meter, headlights and horn get power from the same fuse.
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
John Deere 2210 Compact Tractor (RUNS) (A50774)
John Deere 2210...
Backhoe Attachment (A50322)
Backhoe Attachment...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
1975 Dodge 600 Grain Truck (A50514)
1975 Dodge 600...
2014 Ford F550 Dump (A47384)
2014 Ford F550...
