Hour meter, headlights and horn not working on Kubota B7100
   / Hour meter, headlights and horn not working on Kubota B7100 #1
BalfourGirl
Balfour BC Canada
Kubota B7100D
I've checked the fuses, emergency lights work, the tractor starts, but I can't figure out what to do about the hour meter, headlights and horn. Ideas?
   / Hour meter, headlights and horn not working on Kubota B7100 #2
That sounds like a corroded ground connection, broken ground wire, etc. I would look under the dash for a ground wire that runs to the tractor frame, and take a hard look at it.
Hope that helps.
Thanks Thomas... I'll check that!
   / Hour meter, headlights and horn not working on Kubota B7100 #4
I have the same tractor and I had the same problems and mine was the fuse linkage gone bad. The hour meter, headlights and horn get power from the same fuse.
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
1996 COUNTRY COACH INTRIGUE 40FT RV (A51222)
1996 COUNTRY COACH...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2021 Isuzu NRR (A50323)
2021 Isuzu NRR...
