Hour meter, headlights and horn not working on Kubota B7100
   / Hour meter, headlights and horn not working on Kubota B7100 #1
BalfourGirl
Balfour BC Canada
Kubota B7100D
I've checked the fuses, emergency lights work, the tractor starts, but I can't figure out what to do about the hour meter, headlights and horn. Ideas?
   / Hour meter, headlights and horn not working on Kubota B7100 #2
That sounds like a corroded ground connection, broken ground wire, etc. I would look under the dash for a ground wire that runs to the tractor frame, and take a hard look at it.
Hope that helps.
Thanks Thomas... I'll check that!
   / Hour meter, headlights and horn not working on Kubota B7100 #4
I have the same tractor and I had the same problems and mine was the fuse linkage gone bad. The hour meter, headlights and horn get power from the same fuse.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2016 CAT 289D SKIDSTEER (A50854)
2016 CAT 289D...
2006 TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
2006 TRAIL MASTER...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
McKee 504 3pt. Snowblower (A50774)
McKee 504 3pt...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A50459)
2007 INTERNATIONAL...
