Hot Water Tank Efficiency
/ Hot Water Tank Efficiency #41
For those contemplating the condessing type WHs and furnaces; remember the condensate is highly corrosive (acidic), eats just about anything including concrete.
Ron
No need to exaggerate the problem. In the real world it only means you install a neutralizer on the condensate line if needed. None needed for ABS piping, or even iron piping. Very simple section of 2" X 14" PVC pipe full of granite pebbles. Then you can send condensate out through copper piping if you wish. The best plan is to send it out to a garden area or dirt area through PVC or PEX. I've done it for as long as there has been condensing systems. No problems.
If your heater is installed below grade, a simple condensate pump is available to lift it to the ground level. Very simple setup.
Ron
What makes the condensate acidic?
/ Hot Water Tank Efficiency #43
" It can work out. Myself, I listen to Dave Ramsey. He did a study. 100% of foreclosed homes had a mortgage."
Sorry...just had to comment...if the property did not have a mortgage, it cannot be foreclosed on, because they either own it or rent...some study :laughing:
Weren't we talking water heaters? I am replacing mine this week. Taking out a 40 gal. and putting in a 30, which had to be ordered because nobody stocks 30's. Planning for the future, 99.9% of the time it's just my wife and I, so I went with the small tank with quick recovery which will lessen standby losses, and electric is cheap here so the heat pump design isn't worth the extra expense. I am considering future solar panels to power one of the two heating elements, which would make it, and any replacement, more efficient.
/ Hot Water Tank Efficiency #44
A byproduct of combustion is nitric acid, which is corrosive, but not as bad as Seabee makes it sound. I wouldn't drain to a septic system, but most municipal sewer systems allow it. Condensate from a heat pump water heater is just water...I wouldn't drink it though.
/ Hot Water Tank Efficiency #45
Mine gets dumped into the sump hole and that gets pumped out through PVC pipe to the ground and seeps away. The sump hole also keeps my basement dry and takes the back wash from my water softener as well. I am in the boonies and no municipal anything except road and that is gravel.
/ Hot Water Tank Efficiency #46
You missed the point.
We were talking 10 vs 30 mortgages which has nothing to really do with this, other then money.
I'd still go big. Didnt you wonder why they had to special order it? Did you think you were just a genius ahead of your time?
I don't think it will really matter. But it could hurt resale in a hot market where people could choose.
I just look a good hot shower myself. I am going to put a 30 in at my cabin, since room is limited and will be quicker to drain.
When the water is just sitting there, doesn't take alot to keep it hot. They are insulated decent. In fact a new law came out a couple years ago, forcing you to buy buy ones with more insulation. Which really sucks for tight spaces. But government decided.
/ Hot Water Tank Efficiency #47
You can get away with small tank, by turning thermostat up. Not sure which is more efficent. Heating more water, or less water hotter.
/ Hot Water Tank Efficiency #48
Here is the reason I will not invest in a heat pump water heater,,,
This little girl thinks the scrapped water heater is a "robot"
Heat pump water heaters have not existed long enough yet that ANY should need replaced.
/ Hot Water Tank Efficiency #49
One consideration before buying, HW heaters generally fail by starting to leak. A life of 5-10 years, with an average of 8 years is typical. Hybrids will also corrode and start leaking, and the same life should be expected. If your payback is more than 5-8 years, it is not a smart investment. Also as mentioned, the BTUs you put into the water comes from somewhere. In southern states, where HW heaters are put in unconditioned spaces, along with a warm climate makes more sense than other areas. If you put it in a basement which is not conditioned, you will be chilling (air conditioning) that space. The colder it gets, the less efficient it will be. If it is a living space, you will not only be chilling the conditioned space, but during heating season you will be paying for the heat which is used bu the hybrid HW heater.
paul
/ Hot Water Tank Efficiency #50
My heat pump water heater has failed twice, evaporator coil leaked, was replaced under warranty. Has failed again, I now just use the normal electric coils.
/ Hot Water Tank Efficiency #51
I installed a 40 gallon Marathon water heater to replace a failed oil fired WH. I'm retired and wanted something that would be basically maintenance and trouble free. The Marathon will not rust out and there is no anode rod in it since nothing within will corrode. Well insulated and it hasn't hurt the electric bill too badly compared bills prior to its install.
Marathon Water Heaters by Rheem
/ Hot Water Tank Efficiency #52
I didn't miss the point...you missed the sarcasm.
I don't need big, two showers and wash dishes twice a day. They had to order it because the smallest stocked size is a 40 gal. WTF?...genius no...smarter than some, yes.
I like hot showers also...and I live in a cabin.
Standard water heaters are still one of the most inefficient appliances in the home, although the new foam insulation is much better than the fiberglass of old. The new 30 is the exact same size as the 40 it replaces.
/ Hot Water Tank Efficiency #53
In many areas of the US (cold inlet side) expansion tanks are now required on new/replacement tank installations?
/ Hot Water Tank Efficiency #54
We have a 50 gallon marathon water heater. It is on an energy monitor. The few times we were gone for a day or two I've checked the standby usage. It is practically nothing. It will usually sit in standby without a call for heat for 16-18 hours and then only heats for 5-10 minutes.
/ Hot Water Tank Efficiency #55
I removed a marathon when I installed the GE heat pump one, that has failed twice. I need to switch the marathon back in, just ain't got to it. Also need to pipe in my geothermal preheat.
/ Hot Water Tank Efficiency #56
Point of use ELECTRIC is most efficient.
PoU gas is most economical
There is a difference!
/ Hot Water Tank Efficiency #57
Yes they are, due to the increased use of backflow preventers on the supply line to the home. On a well system, the pressure tank serves the same purpose.
/ Hot Water Tank Efficiency #58
Those hybrid ones have a heat pump to supply most of the energy for heating your hot water. They'll save about 2/3 of the cost of heating hot water, IF the hybrid part continues to work. I've heard of compressor problems with these, and I had compressor problems with the 2 units I put on as retrofits.
The first failure occurred in slightly less than a year: still on warranty. The company I bought the unit from replaced it. However, there was no way I could get the coils out of the hot water heater, but it was old; so I decided replacing the tank was okay.
Then a little more than a year later, the compressor on the new unit went out. I just shut it down and put the electrical coils back into the tank. They were new, as I bought the tank and removed the coils before putting the 30 or more feet of coils containing the Freon were slid in. I still am operating on that tank with the defunct heat pump sitting on top it.
The reason for these compressor failures (vs. a common, everyday heat pump) is because they have to put up much higher head pressure to get the Freon hot enough to heat hot water.
Ralph
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
Ford 8510 (A53317)
Ford 8510 (A53317)
(32) 8" FLOOR TRUSSES (A60432)
(32) 8" FLOOR...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A60429)
2016 CATERPILLAR...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
