hot cylinder
   / hot cylinder #1
peirced
case 450 crawler
how hot should a hydraulic cylinder get. is there a filter that can get clogged
   / hot cylinder #3
Unless the cylinder is next to a heat source... it shouldn't get hot. You have a leak in the piston seal. The leaking oil is heating the cylinder. It will only get worse. Either scoring the cylinder wall or the piston.
   / hot cylinder #4
That all depends on where it is and how hard the system is used. My cylinders got plenty hot when I'm working the tractor hard in field conditions. Hot to the point that it's uncomfortable to touch them. I've never had a seal failure in 20 odd years.
   / hot cylinder #6
If you have a restrictor in the circuit, that will add heat, hard use will generate heat, leaky seals, etc.
Use a temp gun and see of the fluid in the tank is also hot.
New Holland C238 Compact Track Loader Skid Steer (A52377)
New Holland C238...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
Case 950 8 Row Air Planter (A53473)
Case 950 8 Row Air...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A54313)
2017 FREIGHTLINER...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
