hot cylinder
/ hot cylinder #1
peirced
case 450 crawler
how hot should a hydraulic cylinder get. is there a filter that can get clogged
/ hot cylinder #3
Unless the cylinder is next to a heat source... it shouldn't get hot. You have a leak in the piston seal. The leaking oil is heating the cylinder. It will only get worse. Either scoring the cylinder wall or the piston.
/ hot cylinder #4
That all depends on where it is and how hard the system is used. My cylinders got plenty hot when I'm working the tractor hard in field conditions. Hot to the point that it's uncomfortable to touch them. I've never had a seal failure in 20 odd years.
/ hot cylinder #6
If you have a restrictor in the circuit, that will add heat, hard use will generate heat, leaky seals, etc.
Use a temp gun and see of the fluid in the tank is also hot.
(10) 24' Free Standing Panels (A62177)
(10) 24' Free...
Truck Bumper (A62177)
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2017 Western Star 4700 Tri Axle Dump (A62613)
2017 Western Star...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
