hot cylinder
/ hot cylinder #1
peirced
case 450 crawler
how hot should a hydraulic cylinder get. is there a filter that can get clogged
/ hot cylinder #3
Unless the cylinder is next to a heat source... it shouldn't get hot. You have a leak in the piston seal. The leaking oil is heating the cylinder. It will only get worse. Either scoring the cylinder wall or the piston.
/ hot cylinder #4
That all depends on where it is and how hard the system is used. My cylinders got plenty hot when I'm working the tractor hard in field conditions. Hot to the point that it's uncomfortable to touch them. I've never had a seal failure in 20 odd years.
/ hot cylinder #6
If you have a restrictor in the circuit, that will add heat, hard use will generate heat, leaky seals, etc.
Use a temp gun and see of the fluid in the tank is also hot.
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59908)
2020 FREIGHTLINER...
24in excavator tooth bucket (A61307)
24in excavator...
2022 Case CX145D SR Hydraulic Excavator (A61567)
2022 Case CX145D...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A62130)
1987 FORD F-350...
2023 CATERPILLAR 926M WHEEL LOADER (A62129)
2023 CATERPILLAR...
1274 (A62130)
1274 (A62130)
