Horse trailer ?
/ Horse trailer ? #21
Just to answer part of your original question: Torflex is the name Dexter puts on its torsion spring type axle. Almost all the current horse type trailers use this today. I question that it is better than the old interactive two axle leaf spring set up (it 'walks' over bumps and holes very smoothly -- I don't think the Torflex does). I suspect that 'cool factor' and 'the market' have made them popular, though they also are extremely simple to align and install versus a leaf spring axle (4 bolts per axle versus welding leaf spring mounts on and aligning the springs).
Anyhow, we just sold a 25 year old Circle J two horse trailer. A lot of them out there for under ~$4000. Just like looking at a used car: If it looks like it was taken care of and there are no major repairs (frames, tongue, etc) they are probably good. Having said that, they will likely need a couple of these things: lights, or wiring, breakaway switch, battery for breakaway circuit, floor wood, etc. My wife bought it new and washed the interior out after hauling, and also put a stall mat over the wood (easier to clean, some protection for the wood -- which was not pressure treated). Still had great wood after all those years. I have gone over the wiring a couple of times, finally replacing all of it.
Feature wise, acknowledging the multi use stock trailer (note that a tall/draft model is so much better), a horse only model is really nice to have:
1. An escape door for a human (best to actually use a large 5/8~3/4 inch rope through the little door for the horses head; run it from the halter, through the door, and back to the human that is urging the horse into the trailer). This way if there is a 'wreck' the human can escape. Some trailers come with two, but you only need one -- you load the first horse in the stall without one, and the human can go into the other stall. Similar, the second load up the human can use the escape door.
2. We use trailers with mangers. This is the layout on standard straight load trailers. Not common on slant loads (but available). WE DO NOT feed while in the trailer. There may be a 'reward' of a handful of treats for loading (mindset that there is value in loading up-- food). There is always time to eat OUTSIDE where the horse can eat as it should -- neck out, head down (the way the intake tract is designed to be in eating mode). The manger gives the horse something solid to lean into while underway, as well as reserving a place for there head an neck to be.
3. Don't drive down the road with the head window open. Lots of sound, wind, and sometimes a horses head hanging out to be hit by an object (bug, bird, rock). On the road is not a place to need a vet. Not that there is any good place.
4. Not so big a thing, but we prefer chains for butt bars. Not so much to clank and move around if a horse is nervous, and you have more options while moving around to attach it.
5. The back doors should be of the 'dutch door' type. You close the bottom door upon the horse getting in (they can't back out then). THEN you reach over and attach the butt chain.
6. In a straight load, single horse stall trailer, we tether the halter with a breakaway tie. It has a quick release mechanism that is operated by sliding a collar away from the horse. In normal conditions, they can move there head only some, but not enough to be able to step back out of the trailer.
7. Having a tack compartment of some size (the old trailer was under the head/manger area) gives you a place to put two saddles, and enough tack for the horses, plus the emergency stuff, shipping boots (leggings: keeps the horses from stepping on/kicking themselves in the lower legs).
8. If you are going to be going somewhere overnight, you will want to be able to carry hay. On a two horse, that means hauling it on the roof (unless you are pulling with a pick up). Kind of a pain to load, but many trailers have the rack up there. Why not use the hay where you are going? Well, horses can be sensitive, so you want to bring your own hay, as having a horse with colic (you never want that) is a very serious thing.
9. You will want to be able to tie the horses on the outside. That way they can be saddled, etc. The area around where they are to be tied to needs to be safe, including on the trailer. Not usually a problem, but something to think about.
10. We camp a couple of times a year with the horses. My wife is AR (a good thing in a horse owner, as horses have a very tiny brain, and do one thing well: run; that's all you need to do when you are a herd animal with long legs and a small brain), and as a result of experiences and a former competitor in long distance trail riding (the organizations name is lot to me) she has several specifics for tieing them off and leaving them on the trailer: The lead should be tied so that the horses head can just barely reach the ground (it will stretch some when there is a 1000# pulling on it; this is to keep the horse from stepping over the lead and hooking a leg in it and having a wreck), the tire/fender area has to be filled (on the old trailer she put thick foam pads in there, including between the front/rear wheels; this keeps them from hooking a hoof and pulling a shoe, or getting a hoof caught under the edge); water is hung to the side of the head tie so that they can get a drink, but are not likely to spill it (usually the water tie is over the fender). An alternative to this is one I have seen (mostly) on stock type trailers: the fender is a long shelf that runs most of the way along the side.
11. Horses will want to be able to see each other when tied off. Let that help you position a tie off (lead to ground rule) so that they can see around the back corner. They stay calmer if they can see a stable mate.
12. Rear door latches: There are some that are more self latching than others. Mostly the best are only on fairly new trailers, but not necessarily on all the models of any given make. A bored horse will just fiddle around until the open it (it is amazing). Some trailers have ramps. Not a big fan, especially in areas that are cold (the ramp can be slippery). The horse will learn to step up/down, and in the long run will find this to be a more natural thing (plus, they can't step off of the side in a horse wreck).
13. A sign of a well thought out trailer is the hitch. I don't have any experience with goose neck or 5th wheel hitches. The best known of the good ones is Bulldog. It has a side opening latch assembly that wraps around the ball and latches closed with spring loaded collar. Strong, solid, positive latching. On bumper pull models you will find 2" or 2 5/16". Most hitches can be retrofitted.
14. If you have to change the wiring connector, upgrade both ends to the 7 pole blade. It has a 'self wiping' action that helps to keep corrosion cleaned off of the contact points. And it is the defacto standard. Makes it easy if you need to change pulling vehicles. That is also a reason to use a bumper pull trailer, you don't need a particular dedicated pull vehicle (suv, van, pick up, etc).
There are different opinions, and all have good reasons. I tried to point out the easier things to find and use. Especially as you learn what your likes and dislikes are. And your budget grows. We store our trailer such that it is accessible for emergency use. This means it ends up being at the house next to the driveway, so that snow and mud are not problems to getting the horse out (if the horse can't make it out to the trailer, it is too sick to trailer). I added back up lights to my trailer. It really makes it easier to move around at night. I used fog lights mounted so they point out to the side.
Oh -- and please have mirrors that are big enough to see around the trailer. You and everyone else will be much happier.
I'll add a couple of points, and disagree on a couple (-:
1) Ramps are OK, but (always a but) keep them closed up until you actually USE them if it is raining.
2) A horse will naturally try to look behind when backing out.
In a 2 horse trailer this has the potential to become a ramp issue.
The horse will TEND TO try and look over it's shoulder that is not against the wall.
UNFORTUNATELY if you allow this while backing out the hooves will tend toward the edge of the ramp.
So, when backing out lead the head along the trailer wall. The hooves will then tend toward the center of the ramp.
3) Butt bars (or chains) can be a hazard if a horse tries to back out by ducking it's butt under.
Try to minimize the exposure time by loading the horse that is most likely to stand calm and patient first and getting the ramp up (or closing the rear doors) as soon as both are loaded.
I don't ever leave a horse in a trailer with just a butt bar holding it in.
4) Yes, sort of agree on the torque-flex question except for the one BIG benefit which is that they only attach to the outside of the frame.
This means no "axles" running across the trailer, so a lower floor; resulting in lower loading height, shallower ramp angle, less step-up height, lower center of gravity, more stability, etc.
Whats to not luv ?
5) I have never had mangers, but have read horror stories of horses trying to climb into them. I use only straight load trailers and accept that a horse will destroy the fabric feed tray if it freaks out and tries to rush forwards or paw at it.
6) Escape doors; I open up both of them for loading.
It helps to create the illusion of openness and at least suggests that the trailer isn't a dead end trap.
On the head to head trailer I will sometimes open up doors and ramps on both sides and the rear to make the whole thing appear to be "walk through" for a reluctant loader.
7) Since I use ramps I always hook up butt bars before raising the ramp.
Never had it happen, but if a horse tried to back out while I am lifting a ramp things could get really ugly very quickly.
8) My PREFERENCE is the head to head trailer. Every horse gets to walk out forwards, any horse can be taken out without disturbing the others (at shows, then put back and others taken out) and the "face space" in the middle just has to be better than facing a corner.
9) Back up lights; I re-wire the rear loading light with a 2 way switch (center off).
One position is normal loading light, other position is to the back-up light wire.
It isn't THAT MUCH of a light to see with as much as it is a warning light to other drivers that I am coming backwards.
On the big gooseneck trailer I also added "tractor lights" on each side at the front and aimed back at the tires.
Rationale; Where those tires are about to go to is what I want to see in my mirror as I am backing up in the dark.
Mirrors: I respectfully disagree on the need for ever "seeing around" the trailer.
I cannot see vehicles narrower than 8ft if they are centered behind me, in fact with the gooseneck trailer they could be almost 8ft 6in and not be visible.
For BACKING; it is ALL done with mirrors and the one that matters is the one on the inside of the curve.
This is about the simplest description I have heard of how to back a trailer;
"Drive the trailer wheels that are on the inside of the curve."
They are the only ones you can see in your mirror anyway and if you get those around the curve right (assuming there is enough clear width) the rest of the trailer will go where it needs to.
It only takes a very slight bend between the truck and trailer to lose sight of the outside wheels anyway and the inside wheels are EASILY seen.
Not disagreeing for the sake of it, we just have different opinions on this.
/ Horse trailer ? #22
I really feel the need to respond to #5. I had a two year old Arabian actually stuck with her front half in a manger. This was not pretty or cool by no stretch of the imagination. To this day I have no idea how she did it.
/ Horse trailer ? #23
I haven't noticed much difference in floor height with either axle type (apples to apples type trailers), but every inch closer to the ground for smooth road trailers is always better.
My reference to trailer mirrors is that I see a lot of trucks with trailers wider than the truck and the truck has the standard (versus towing) mirrors. Having wide enough mirrors to see around/along the load not only lets you see what's going on with the side of the trailer, it also lets you see how long the line is behind you, if they are flashing you for a trailer/load problem, and it helps you to realize when you are driving over the center line. A lot of people have precious little idea where they are in there lane (and all of us could use an easy tool to help us -- me too).
Good tips on the back up lights. I like them.
Something that most of us forget when driving a vehicle: the inside rearmost tire of a vehicle (including trailer) is the pivot point for the load and the tire you are steering for, regardless of where the rest of the vehicle is. Saves some curbs that way (and reminds me every time I do it).:eek:
/ Horse trailer ? #24
All good points on loading up our equine friends on trailers. We have two trailers, a stock and a 2 horse straight load (the stock is the one I posed the question about Line-X on earlier).
My two cents is I'd like to have the butt bar up before putting up the ramp. My logic is similar to that of Reg. We have had to deal with "nervous loaders", including draft crosses (Percheron x Thoroughbred) who weigh 1600 - 1800 lb. Loading was a 2 person operation until the horse got used to trailering again (had a bad experience on a slant load with a trainer, don't ask me what she was thinking trying that). One person lead him on the trailer, calmed him, etc, while the other got the butt bar up. Once or twice, he would back out quickly. If the butt bar was only half up, not a big deal, it just goes back down again. On the other hand, if I had been putting the ramp up, that would have been UGLY.
There are a million ways to load a horse, all are correct for a particular situation. Some horses you need to push from behind. Others, if you try that, you are going to get kicked into next week (or worse...). Assess your situation, and decide what is best for you...
My two cents... :)
/ Horse trailer ? #25
Dump the trailer. How much does that horse mean to you? Sounds like that trailer is trashed all over. For your safety, your horse, and other people on the road, don't use that trailer. Don't mean to sound judgemental, Chris, but it sounds like it would be cheaper to buy a better trailer than to try to fix this one up.
You dont want to be pulled over by other traffic, telling you that there are some bloody stumps sticking through the floor... Never seen it myself, but its a nasty sight, i'm told.
Whatever you do to it to fix it up, -please- start with the floor....
/ Horse trailer ? #26
Hate to jump on Ya about this, but I wouldn't;
a) Put two horses in the rear half of a trailer and ONLY a 4 wheeler in the front half
b) EVER tie a horse that isn't stalled.
c) EVER use a bungie cord tie.
Rationale;
a) Weight distribution. Likely to contribute to sway.
b) Risk of neck wrench if you have to brake and the horse stumbles.
c) When those things break, and they DO, there is a sling shot - one end of which is on the halter very close to the eye.
As I said, I hate to jump on Ya, but PLEASE reconsider all three points.
gotta agree. A stock trailer is so named for a reason. it's for stock, not horses. A horse trailer is designed to be a horse trailer. The horses have less ability to move around, get in bad positions, can't mess around with each OTHER etc etc. I'm sure a lot of people move horse in stock trailers but it's a compromise. I'm also sure a lot of people use barbed wire for field fence. Doesn't mean it's a smart thing to do. Get a trailer designed for horses unless you really like your vet and like their bills.
Oh - not on my tools list because it's really the wifes, but we also have a 3 horse gooseneck w/ dressing room horse trailer.
/ Horse trailer ? #27
There is some great info so far in this thread.
I agree with poster that the floor has to be good. With mats sitting on top, they hold moisture.
I would add to some already excellent posts, to go hang out with horse folks and go along for a ride a couple times. I got to before I got my trailer(no longer have horses or trailer). I had an idea what to expect when loading, hauling, unloading.
Driving with a live load is a lot different than trailering a tractor or other "static" load.
I drove slower than with my tractor/trailer combo. Anticipated stops and corners much much more. Thought about what it is like to stand and walk in an airplane, bus or RV while in motion, ie what the horses are feeling back in the trailer.
If I were looking for a trailer, I would look real close at the floor. Then the frame, axles, and attach points. Tires on trailers do not age well...
Getting a used trailer, perfect or poor shape, the first thing done at home is up on jack stands. Bearings get removed, cleaned, and greased at a minimum. Brakes get inspected and repaired as necessary, since they have to come apart to check the bearings anyways. A new breakaway battery is cheap, so it gets a new one.
The connector gets switched to 7-wire so I do not have to use an adapter. All the wiring and lights get checked and repaired as needed.
/ Horse trailer ? #28
One or two other GENERALITIES that are peculiar to horse trailers and somewhat to other enclosed trailers.
1) They are usually HIGH, say 9ft or more.
This means they pick up wind, so those "Warning strong cross winds" signs mean YOU.
2) The center of mass (of the load) is also fairly high and it does move, however the center of mass of the trailer itself is very low. Above about 4ft there is typically only enough structure to hold the roof up and keep the weather out.
3) Off ramps - those 30 MPH and 20 MPH ramp speed limits DO apply to horse trailers.
Yeah, REALLY !!! Please don't take the customary 10 or 20 over.
I "try to" moderate my speed with engine braking, that is to say I stay off the brakes.
I use tow/haul mode to get it to downshift and will sometimes tap the brakes to signal that I want a(nother) downshift.
Not all trans do this, but mine has that algorithm that causes a downshift if the brakes don't cause a drop in speed.
So, VERY GENTLE slowing down and cornering as well as correspondingly gentle acceleration - I don't NEED great gobs of power and I'm sure the horses wouldn't appreciate neck snapping stop light take offs (-:
2007 FREIGHTLINER CL112 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59912)
2007 FREIGHTLINER...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2017 VOLVO VNL  6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2017 VOLVO VNL...
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
UNUSED WOLVERINE QUICK COUPLER 4 (A64281)
UNUSED WOLVERINE...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63688)
2006 Cadillac GM...
