Hoover pole barns
/ Hoover pole barns #1
USAFpj
SC
1957 841 Powermaster
guys, I'm looking at a 30x50 pole barn by Hoover Buildings, in Upstate SC. In our region, we have 4 distinct seasons, with high humidity in the Summer. The insulation that they can add as part of a package is rated at R7. This would be in the ceiling and side walls. Is R7 enough to fight condensation issues by itself, or are you guys running a fill ridge vent as well? I don't plan on heating and cooling it mechanically, but would like it to stay reasonable year round.
/ Hoover pole barns #2
You will still get some condensation, but hopefully they run plastic over the top of the insulation so the moisture can drip onto the plastic and work it's way down to the outside of the building without getting the insulation wet. I would think it would be minimal and probably something you would never notice if it was done correctly
/ Hoover pole barns #3
I think the stuff I use is R10. It's a roll with foil on the outside and white on inside. I still run a full ridge vent.
/ Hoover pole barns
Barnbuilder, do you get any condensation at times? Do you think the ridge vent was necessary without eave venting?
/ Hoover pole barns #5
Haven't seen any but not around much after I leave job. No complaints but I also use a perforated soffit.
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
Case 1845C Skidsteer Loader (A66285)
Case 1845C...
2022 FORD F-450XL FLATBED TRUCK (A64277)
2022 FORD F-450XL...
2014 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2014 CATERPILLAR...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2007 Kia Amanti (A66408)
2007 Kia Amanti...
