Bucket Hooks Hooks on bucket.
/ Hooks on bucket. #41
From what I can see in the pics the addition of hooks to the bucket are the equivalent to the kiss of death for tractors and they never work again/forums/images/graemlins/grin.gif
If I weld hooks to my bucket will it get all shiny like those pictured?/forums/images/graemlins/grin.gif
Does anyone have any pics of where not to weld on hooks to a bucket? Why don't I see any on the inside of the top lip?
Thanks,
Martin
/ Hooks on bucket. #42
</font><font color="blue" class="small">( From what I can see in the pics the addition of hooks to the bucket are the equivalent to the kiss of death for tractors and they never work again/forums/images/graemlins/grin.gif
)</font>
Well, my bucket isn't shiny...
/ Hooks on bucket. #43
Another not-shiny bucket (Attachment).
My well-used bucket came with only an unreinforced hitch ball at the center. I think that was used to lift the 700 lb disc that has accompanied this tractor for 20 years.
I bolted on four Cold Shuts (chain splices) rated 2600 lb SWL to make chain attachment points. Chain threaded over those points won't bounce out when it goes slack, and they make a good place to carry chain when it is not in use.
This wouldn't be suitable for heavier loads but considering stability in motion, I don't expect to carry anything heavier than that disc.
/ Hooks on bucket. #45
</font><font color="blue" class="small">( and they told me to step up to a bigger MIG unit, and not to bother with stick. Cost aside, would MIG weld something like this securely? I use my hooks very much, and for heavy stuff. )</font>
Two pieces of 1" plate for a backhoe ripper tooth.
/ Hooks on bucket. #46
Welded together and cutting edge built up.
/ Hooks on bucket. #47
Completed.
/ Hooks on bucket. #48
Ripping out a 10" - 12" white ash stump.
/ Hooks on bucket. #49
Laminarman,
That 1" plate was welded with a Lincoln PowerMIG 210 - which is only rated for 1/4" or so (single pass, using solid wire MIG process) .... and it hasn't busted yet. If you use multipass and proper technique you can weld much thicker metal than what the machine is rated for.
Why was the dealer steering you towards MIG ?
0. It's a bigger sale for him .... no doubt. But ..... maybe that's what he would believed you would be most happy with.
1. It's easier for a beginner to pick up (you don't have to move the rod in as you try and weave and travel along the weld path, which sometimes is hard enough /forums/images/graemlins/grin.gif)
2. It's cleaner than stick - very little flux to clean off after you've finished, makes nice looking welds.
3. It's fast.
4. Errr ... did I mention it was fast ?
/ Hooks on bucket. #50
Pics taken delivery day, 2004. It isn't so shiny these days... /forums/images/graemlins/wink.gif
/ Hooks on bucket. #52
My TLB came from the PO with hooks on the front bucket, similar to what others have shown. Really handy for logs and stumps too big to fit in the bucket.
I've had a chain loop permanently on the backhoe bucket for many years. It is a convenience, but hard toadjust the length of the attaching chain since the end hook had to be on the loop, or else run the chain through, etc.
Now that I have a welder I've finally gotten a hook back there, too. most convenient. I've kept the chain loop on for the really hard pulls - or something that might snatch, like pull starting the hunt club's dump truck.
Wm
PORTA POTTY (A67714)
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
2023 CATERPILLAR 259D3 SKID STEER (A65056)
2023 CATERPILLAR...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
1977 Dodge B10 Cargo Van (A66736)
1977 Dodge B10...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
