Hooking up backhoe??
/ Hooking up backhoe?? #21
Unplug short hose from P and let hang out of the way (put dust cap on it). Plug male BH hose into P, then female BH hose into T and you are done.
Good response, but a response no one will read.
/ Hooking up backhoe?? #22
Is the engine off when you are hooking up the hydraulics? pmsmechanic asked in the post 14 if there is pressure in the lines. If it will not connect, you have pressure in the backhoe or tractor. You will need to relieve the pressure. If the engine is off, the pressure is in the backhoe.
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
2016 DODGE RAM 1500 4x4 CREW CAB PICKUP TRUCK (A59912)
2016 DODGE RAM...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59912)
2016 FREIGHTLINER...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2023 BOBCAT T66 R-SERIES SKID STEER (A64279)
2023 BOBCAT T66...
