Hood prop rod
/ Hood prop rod #1
wombat
And another thing.
My Green ym2000 has a removable rod around 2ft long and 10mm thick clipped to the left hand side chassis rail.
I can only think that it is a prop for the bonnet but I can't work out where it goes.
My tractor has an after market air filter set up with a barrel type filter in front of the radiator top tank. Does the origional flat, round filter case have a socket for this rod to fit in?
Wombat
/ Hood prop rod
C'mon Guys.
Hasn't someone seen this thing?:confused:
It has a rubber cap on one end and a small pin across the other end.
I'll take a pic next week when i'm back out the farm.
Wombat
/ Hood prop rod
This should be it.
/ Hood prop rod #4
Sorry Wombat,
Not ignoring you, but thats the old style YM2000. Not at all familiar with it. Nice looking tractor though.
Bruce
/ Hood prop rod #5
That's the first time I've seen a hood 'prop rod' on any Yanmar tractor.
/ Hood prop rod
Thanks Guys.:)
She's a great old clunker,loves to work.
The prop could be an add on but it has me perplexed.:confused:
It doesn't seem to fit anywhere, but it looks original.
I might have to make up a bracket to slip it into under the hood.
Wombat
/ Hood prop rod #7
Wombat, what are those front tires? I'm wondering if an automotive tire would gouge less and steer easier than rib front tires.
Comments?
(And that's sure a unique color, isn't it! :D)
/ Hood prop rod
Cali, those are light truck tyres.
They were on it when I got it, rice tyres on the back.
They steer pretty good except in soft, wet soil. Then they push/slide a bit and I have to use the L/R brake to turn tight. Cheap and easy to get though.
The green is a bit hard on the eyes some mornings, probably due to the previous nights activities though.;)
http://
Wombat
/ Hood prop rod
Bump.
Hi folks.
I have made a bracket for this.
It works well. nomore getting hit on the head for me.:)
You can see prevoius wear on the inside of the hood/bonnet.
/ Hood prop rod #10
Looks good Wombat. Now I understand your need for a prop. All the Yannies I had seen have the hood which tilts forward.
Bruce
