Honey bees
/ Honey bees #121
HH use what you have for swarm traps. If you make a box just for catching swarms you will have to move them to the hive box you use. One more chance to kill the queen. Also swarms grow fast. I have had boxes just for swarms and got tired of having to move them to another box each time. Now I use the same 10 frame deep they will stay in, for my swarm traps. If they are a large swarm all you have to do is add another box. I have caught swarms that filled 2 deep boxes.
/ Honey bees #122
My bees decided its spring.
/ Honey bees #123
I don't like to hijack the thread but I have bees living in one of the hollow brick columns on my front porch. I have checked under my soffit and in my attic and no signs of bees there. I think the only entrance to the column is where the bees are entering. I am about to drill a hole through the mortar in the column to see if I can see honey or anything inside.
I contacted a guy who removes bees and he wanted a fortune to remove them. I called an exterminator and he was real cheap but I don't want to kill them. If they are just filling up the column with honey, is there any reason I can't just leave them alone?
/ Honey bees #124
I personally would not want to have bees on my porch. I would think that would be quite the liability. But I guess that's a personal preference thing. They will probably leave you alone most of the time except for mid-summer and late fall. They might get feisty then. If they have just moved in I would take care of it soon. If they get established for very long at all then die, you will probably be dealing with bugs and a smell for a while.
You could probably work out a way to install a bee escape on the entrance which works like a 1 way door. When the foragers go out they would not be able to get back in. That might reduce the numbers enough that they might want to abscond. If they don't all abscond the hive will eventually die. You might put a hive with attractant close by if you do the escape, the foragers might settle into the hive provided out of desperation. Of course they may just find another way in too...
/ Honey bees #125
LBBJ is correct.
If they move out or you kill them you will have all of the old comb, honey and pollen inside the brick column. Then you will have yellow jacket's and mice getting in to clean it out.
Yes I do removals and they are not cheap but there is a lot of HOT, hard work involved.
Most of the time it takes weeks until the hive is reestablished and even then they have to have feed.
The first time someone gets stung you will be rethinking about what should have been done.
/ Honey bees #126
can you smoke them out, then fill the hole? look up bee smoker.
/ Honey bees #127
Especially if the person stung is allergic to bee stings. My dad discovered he was allergic at about 40 ... almost died from the swelling in his throat within 15 minutes of being stung.
/ Honey bees #128
That is a candidate for a trap out. A cutout will require demolishing that column. Even trap outs can be less than reliable.
If the bees die in there and the honey not removed, you will have other pests working to get in there, the stench of thousands of dead bee larvae is incredible.
Not an easy solution.
/ Honey bees #130
There is a good chance just because they are going in right at the corner of the column they aren't neccesarily living in the actual column. They could be in between the rafters on the porch roof structure, much easier tear out than removing the column. An easy way to find out would be to take out that vent right there and have a look. I would suit up though.
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A62130)
2008 FORD F350 XL...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
GENIE S-60 MANLIFT (A58214)
GENIE S-60 MANLIFT...
2014 Freightliner Bucket Truck (A61307)
2014 Freightliner...
