Homemade tractor?
/ Homemade tractor? #21
/ Homemade tractor? #24
Interesting..maybe one day gentlmen will drop by TBN and tell us all about it. :)
/ Homemade tractor? #25
I made a trip to Louisiana to help a friend cut up some old farm equipment, mostly for parts. One of the things we didn't do, that was sitting in that old field was a hi-crop sprayer, which really looked a lot like that tractor, except a little smaller. The drives were chain driven, by stainless steel chains, about a #40, with a 4 cylinder Continental Engine for power.
David from jax
/ Homemade tractor? #26
Is it just a figment of my imagination or is that an empty winch drum just under the truck rear end and slightly to the right of center in the rear view pic?
/ Homemade tractor? #27
anyone live near that station to stop in?
/ Homemade tractor? #28
We used something like this years ago. It is a highboy sprayer. In the spring and early summer you put tanks on it and spray tobacco. Later in the year you pull the tanks off and use it to drop sticks in the tobacco rows before cutting. The one we used had a car rearend with chains run down to the wheels which were much smaller than the one in the pics. It had a small four cylinder engine and an old granny trans. the pump for the sprayer was ran off a belt from the front of the engine. Well this is my best guess about the one in the pics.
/ Homemade tractor? #29
Very interesting machine, it may have a particular purpose or could be this person just got crazy with his welder, i'm thinking that because of the single front wheel maybe what ever his use would be has for need of zero radius turning, ;)
/ Homemade tractor? #30
I was going to vote for Tobacco or Cotton. Center wheel is a bit cumbersome for row work, but height and displacement would look to apply in those enviroments.
/ Homemade tractor? #31
Tell that to all the tractor companies that made single or narrow front end tractors. MH, Case, IH, JD, Oliver, and others all made them for row crop use. Case VAC is an example.
/ Homemade tractor? #32
looks like a homemade spray tractor. The old JD and IHC and other High Cycles as they were called were set up on this and several newe JD's have a 3 wheeled set up. @ row cultivation tractors also had a tricycle set up for cultivation. When I was 18 I was working In CLarksdale ms building a parking loat for a plant I was on my scraper and saw a larrge 4 wheeled spray tractor comming down the road then out from under it a nut on a Harley ran out from under it. It was 2 brothers that farmed and that was one of the things they were known for.
/ Homemade tractor? #33
Sorry, I just meant that particular version in the picture of the "single wheel" tractor. The tires looked a bit wide for row work. We had a number of Cases and JD 3 wheelers in Iowa, but by the time I got to Wyoming it was going 4 wheel... I remember the 3 wheel as turning on a dime and scaring the heck out of you on a slope...
/ Homemade tractor? #34
It may possibly be a Thieman kit tractor from the 1930s. I have one and without seeing better pics of the frame I'd say it's possible this one is too. GOOGLE Thieman tractor.
/ Homemade tractor? #36
Thieman didnt make anything that big I dont think. You have a rare treasure, I saw a Thieman go for 26,000 at a sale once. I read that Thieman had 150 employees working 24 hrs a day.
/ Homemade tractor? #37
May as well get my 2 cents in,...so it looks to me like it runs in a few feet of water with a solid base, (known bottom). Hence the rusted wheels and undercarriage, and non baloon tires,..(not worried about traction) perhaps the light(hangy-down) chain holds an implement not too heavy(praps it even floats?) that can be quickly changed off for something else.
"Cranberry" harvesting comes to mind and they have in the past used a variety of implements from high wheeled to boats to pedal powered etc but perhaps some other "water-crop" along the lines of the cranberry sort crop?????
Speakin' of the Everglades, . . could it be for slinging up and draggin' home a large shot (or muzzle-wrapped) Croc or Gator or some such wild idea as that? .....wha-da-ya-say JJ ? (OR is that even legal now-a-days ?)
Heck don't go laughin, . . I'm a Canuck,..wha-da-we-know bout swamps? Well at least our swamps don't often grow crocs and gators,.....on the other hand I surely do enjoy a feed of Gator-Tail down there at Destin's Fudpuckers!!
Since I'm a Canuck, ignorant of such things, I might ask if it could be for carrying bails of cotton in from the field? ...So OK,...what're my guesses worth,...any change from my 2 cents?
CHEERS!
. . tug
/ Homemade tractor? #38
That Field Day of The Past sure looks like a blast . Meant to go this year , but family illness held me back . For sure next year !
/ Homemade tractor? #39
Sadly, the other pictures didn't turn out, but I saw a Farmall at the fair which reminded me of the thread.
Aaron Z
/ Homemade tractor? #40
THE ANSWER IS????? A home made self propelled log arch,....;) The guy who built this, has done a couple more, I ve seen pics of this tractor sitting in a shed with his other, skidder creations, over on the Arboristsite.com :thumbsup:
CrusterBuster 4000 Grain Drill (A63688)
CrusterBuster 4000...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
Used Landpride GR1525 Stump Grinder
Used Landpride...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
2012 International Prostar (A63118)
2012 International...
2022 BOBCAT T870 SKID STEER (A64279)
2022 BOBCAT T870...
