Homemade Tool Bar for Garden Bedder aka Disc Hiller
   / Homemade Tool Bar for Garden Bedder aka Disc Hiller
In your original post, it's the 4th picture down. Date in the corner is Mar 7 2012. The picture shows the beta version when I was playing with the idea. A piece of 2" square is temporarily sandwiched between the upright, and the pipe to hold the cultivator shank. There are 2 nuts welded to the pipe to grip the shank.
The ground where our gardens are slope towards a swale. We use tote tanks to haul water in from the river. Open the valve and let it flow seems to be just the right rate to allow water to flow and soak in the rows. Typically, we get plenty of rain early on, till about June for the first crops (potatoes, green beans, cauliflower,etc). Only have to water the blackberries, raspberries, pumpkins, indian corn etc.
For your lower pins of your 3-pt hitch - it's 4" x 4" angle that you used for the pins?
   / Homemade Tool Bar for Garden Bedder aka Disc Hiller #22
Before toolbars came along cultivator frames were used by farmers. I have a couple of six footers. They can be found around here in scrap piles, fence lines, or junk yards pretty cheap. Holes are at 1 inch spacings. View attachment 738362View attachment 738363
Oh, don't give too many of those hole in angle iron tricks away. All around the country STOP SIGNS will then disappear and turned into farm equipment. LOL
   / Homemade Tool Bar for Garden Bedder aka Disc Hiller #23
When the neighbors Toro Zero-Turn died, I got the ROPS, but we couldn't find the hinge plates. The ROPS were of no use for him, so after he bought the Toro, he took them off immediately.
My plan was to make a DIY hiller from these Toro parts shown below. The width of the ROPS loop fits within the rear tire pattern of my machine.
Then using the bolt on hiller discs it's almost ready. I just have to be keen on the 3PT attachment
On many of the Japan made PTO tillers, the hiller could be manually put into place and angled as needed. It's rare to find these tillers with the hiller discs in North America.
With that said, I too am interested to make my own hiller for kennebec potatoes. :)
That's a really cool setup!
The 2"x2" bar - U-bolts for connection plates - were you able to use a 2" U-bolt (2" inside the legs) or did you have to go up to 2-1/16" or 2-1/8" between the legs? I'm afraid the 2" u-bolts won't clear the 2"x2" bar. What's your experience?
Two options I've found, if I have to go more than 2" - I'm thinking the Galvanized 2-1/16" between the legs would work best - any thoughts on that?
   / Homemade Tool Bar for Garden Bedder aka Disc Hiller #28
For the price, those look like Grade-2 strength exhaust U-bolt hanger types. Wimpy overall.
Grade-8 for the application is needed. Some are listed as 8.8. These are heat treated and coated.
These types of U-Bolts are the automotive grade to clasp down leaf springs. These would run about $10 to $18 each.
Even enclosed cargo trailers would use the higher strength Grade-8
Boat trailers uses stainless.
Ford F-150 uses the 2.25 wide sq U-bolts if you need wider.
I went with these 1/2" diameter galvanized ones, which are the same ones used on my boat trailer with a 2x2 square axle. Should be more than ample strength with 1/2" diameter.
   / Homemade Tool Bar for Garden Bedder aka Disc Hiller #30
Yeah, you can use grade 8 or whatever you think you need. I just made what was needed using some grade whoknows 1/2" bolts and some scrap pieces of 1/4" diamond plate to make the brackets. It's what I had in the shop, and is plenty tough enough. Welded the pipe to a 3"x5" piece of plate, and cut 4 pieces of the plate into
1 1/2"x5" straps. Maybe this picture shows the brackets better. I did use u-bolts similar to what you show for the cultivator shank mounted on the 3 point upright. Again, more than strong enough for the application. Hope this helps.
Edit: I need to correct some dimensions from my earlier post. The hiller crossbar was fabbed to 44" to fit inside the 48" footprint of my old 50 8N. I now have a 66 1020. It has a 5' center tread to center tread width. In both instances, the width of the hiller to tread width allows for cultivating the rows. Important for weed control, and in potatoes hilling or laying up in the rows. You're driving on an established tire track which is easier to keep 3 point tools on track and not digging up crops.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2017 FREIGHTLINER...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
