Homemade loader for Branson tractor
/ Homemade loader for Branson tractor
Thank you Nuno.
The loader is finally done. Or it's 99% done. Just need to touch up the paint here and there.
The painting process came out nice, although the paint we bought doesn't match the tractor paint quite well. Even though we took two parts from the tractor to the paint guys, they still couldn't quite match it right.
I'll eventually do a slideshow video with some machining clips and the pictures from the whole build.
IMG_20191011_163114.jpgIMG_20191011_163124.jpgIMG_20191011_175401.jpgIMG_20191011_144440.jpgIMG_20191010_182436.jpg
/ Homemade loader for Branson tractor #42
Very nice, beautiful workmanship.
Do I detect a lack of the front mounted bar?
Enjoy using your new loader.
Lou
Thank you again Lou.
Do you mean a cutting edge on the bucket? I do have one. I just beveled and welded a piece of flat bar all the way across. We don't get any snow here, so I don't wear cutting edges that much.
/ Homemade loader for Branson tractor #44
No I was mentioning the front mounted rops originally on your tractor.
I could see where that would be in the way quite often.
Oh that. It's just folded. It folds over the hood. I have a lot of trees here in my home and I can't really do any work with the ROPS up but it's a flat place, no hills or anything like that. 50 miles away, where I put most of the hours on the tractor, is very hilly, so I always run in the ROPS up and I also put it up whenever I'm roading the tractor.
/ Homemade loader for Branson tractor #46
Thats interesting I had no idea that they would fold down like that, certainly makes it more user friendly being able to fold it.
I went back and looked more closely and then I saw it, nice to be that foldable.
It's indeed a very nice feature. With a rear mounted ROPS, even folded, would create me a lot of issues. I can get a much lower profile with this style of ROPS.
/ Homemade loader for Branson tractor #48
The color looks good to me but maybe it's because I'm to far away, why is there two controls on valve bank, on e long handle a shorter one?
Could be an optical illusion but the lift ram looks like it could hit that horizontal bar and the only weak point I can see is at the front, maybe the side plates should be bigger.
On the controls, I have a Rexroth 3 spool valve. I believe it came from a Case loader or backhoe. I've converted 2 of the spools to a joystick used for the loader functions, while the third spool has its own lever and controls the winch or also allows me to add a 3rd function to the loader if I ever need it.
It's optical illusion. The cylinders won't hit the horizontal bar, plus when fully retracted, it doesn't get below the top of the bar.
As far as the weak point, it may or may not be, depending on the use but I don't think I'll ever push the loader that hard. If it gives me any problems, I can always add some plates like you drew.
/ Homemade loader for Branson tractor #50
Ok so the long lever control's the FEL, great job, you ever use that front winch much? Wow that picture angle really shows the ram clearance...:thumbsup:
/ Homemade loader for Branson tractor #51
That is very impressive and you have amazing skills. I have to wonder though how much time you spent on this and if you came out ahead? Someone with your skills likely earns a pretty good wage. I too like to build a lot of things myself ( not of this caliber) but I have found over time that I am often ahead spending my time doing what I do for a living and just buying the item instead.
Actually, I do use the winch for all kind of stuff. I use it much more than I thought I would.
Thank you bdog.
I started this project about a year ago. Then I stopped messing with it for about 8 or 9 months. So in the last 3 months I've been pushing this a bit harder. It does take a lot of time to make this. I had a bit for free time, so it was not a big deal.
I do like to make my build my own things. It's always a learning experience and you can make it fit your needs.
I spent slightly less 1000$ on this loader, not counting my time. This includes 4 cylinder seal kits, chrome rod (6.8 ft), cylinder barrel (6.5 ft), control valve (50$ used), 32 ft of 5/8" hydraulic tubing, various hydraulic fittings, hoses and quick disconnects, a couple runs to the scrapyard to get sheet metal for the bucket and some other parts and a couple runs to steel supplier to get stock for pins and so on.
I had most of the steel on had. The rectangular tubing came from a A-frame crane I had. If I had to buy everything, I think it would go over 3000$, not counting my time.
I could send the tractor to a company up north and they would mount a new loader on my tractor for about 2800$. But they would just send the tractor back with the weights and winch sitting on the bucket, which is not something I want.
/ Homemade loader for Branson tractor #53
How much FEL weight is your tractor rated for and is your bucket the right size for that? My tractor bucket is 5'wide, will lift at full height with a full bucket of dirt @ around 2000 rpm, it's all it wants. I figure if it's is design to lift that then it shouldn't break the front end.
Looks like you now have a cutting edge on the bucket now, have you done a new video lately on digging dirt?
There is a tag on the tractor that says the Permissible front axle load at 870 kgs (1918 lbs).
I built the loader by matching the specs with the loader that Branson sells over there in the US and the for the design, I used some pictures from a local company that builds loaders and all kinds of attachments.
I did run some numbers some time ago, I was getting around 1600 kgs (3527 lbs) lift capacity at the pins, close to the ground and about 750 kgs (1653 lbs) full height (106").
The bucket is much narrower that what you guys use there. It's 51" wide. I'm sure I can lift a full bucket of dirt at full height easily, just idling.
I don't have any video of it working for now. We're having quite a bit of a very welcome rain at the moment and I don't really have any dirt work for the loader for now. Mostly carrying wood once it stops raining.
/ Homemade loader for Branson tractor #55
Any special reason why you chose 51"? It's probably safe to say that your loader wont lift more then the tractor pump can put out. Thanks for all your pictures and input, I know that can be time consuming.
For two reasons, one is because 51" is 1.3 meters, which almost matches the width of the tractor (1.4 meters or 55"). The second reason is because the 5/16" thick sheet metal I had from the scrapyard had a really bad dent at around 52" and I really don't have a good way to deal with that.
/ Homemade loader for Branson tractor #57
Thanks for mm to inches, saves me time of looking it up, I'm still in the dark ages with the metric system. I think your 2nd reason is the main reason for 51", dealing with dents is an art, at the ship yard they spot heat then drench with water to straighten out steel. Is all of that bucket 5/16"? that's heavy duty. My bucket is 1/4 thick at best with a 7/16-1/2" x 6" cutting edge, it has wore down some in ten years.
The second reason definitely makes for the first one. I don't have a oxy acetylene torch, so that makes it even harder.
I bought the sheet metal at the scrapyard. All they had was this massive piles of 20" x 120" x 5/16" sheet metal. And managed to spot the only 1/4" in the middle of the pile.
So I used the 1/4" on the bottom, since doesn't see the much stress as long as it has a cutting edge and using the 5/16" on the back and on the sides. The 5/16" on the back gives me a better base to weld the attaching points for the quick attach.
This makes the bucket quite heavy though, to the point that I barely need the supporting legs when I take the loader off.
/ Homemade loader for Branson tractor #59
Yes 5/16 on back and sides was a good idea. I didn't notice the quick detach part of you loader build, I have to do that to my loader sometime. How you cutting steel, plasma?
I decided to go with the Euro style quick attach, instead of the skid-steer type. The Euro one is much more common over here and in my opinion, it's a stronger system than the SSQA. I did maintain the standard dimensions on the quick attach, in case I ever have the need to sell the tractor, the new owner can get whatever attachments he wants for the tractor and it will fit right up.
I used to cut steel with a 4" and 6" angle grinder and when possible, I also have an old power hacksaw. But sometime in January, I came across on one of those cheap plasma cutters and I have to say, that thing is a must to have.
Cost me 140$, it's a 40 amp machine. It will struggle a bit with 3/8" stuff, but will leave a decent finish on 5/16". I can't count how many cutting discs for the angle grinders I've saved with the plasma cutter. I also made cutting curves and shapes much much more easy.
