Dan69GTX
I've enjoyed reading what others have done so I figured I'd post another one of my creations.
I built this several years ago. I needed a lot of air for sand blasting but didn't have the funds for a large compressor...so I built one.
The donor vehicles were - an old trailer - for the frame and a 1983 Honda Civic - for the engine (compressor) and transmission. The modifications to the engine: Can't remove the cam because it drives the oil pump, so all rockers, etc were removed from the head and all oil passages welded shut. Remove the intake valve springs and replace with real light springs (the suction from the piston pulls air past the intake valves - in other words they just "float"). Remove spark plugs and replace with check valves brazed to "spark plug no foul" adapters. Remove carb and build adapter to take a GM air cleaner assy (much cheaper air filters than the Honda's). Add a hose to the heater tube on the head and attach to plastic antifreeze overflow container - this allows for expansion of antifreeze. The existing water pump circulates the water - no radiator needed. Weld an adapter to part of a rim to allow a PTO shaft to connect to it. The transmission is used to turn the compressor. I used the correct side to allow me to select gears 1-5 to best match compressor RPM to PTO speed for max air output. Too fast and the intake valve float too much and you loose efficiency.
The check valves are plumbed together and run into a "manifold" which goes through an air to air heat exchanger, which goes through a large check valve, which goes into the exit manifold that has a pop off valve (from an old boiler), pressure gauge, connection to tanks, ball valve (for drain) and quick connector. The radiator fans from the car are mounted over the heat exchanger to help with cooling.
The heat exchanger is from an old house water to air heat exchanger for a boiler unit.
The air tanks consist of a tank from an old air compressor and a 100 gal propane tank.
Everything is bolted together so anything can be removed/repaired.
It served me well for several years. Now it only gets used when I need portable air.
