Homemade 3 PTH Winch
/ Homemade 3 PTH Winch #1
David Devuono
Platinum Member
Brampton, On\lot Powassan, ON Canada
Kubota B4200\MF 135\Kubota B3200
Note quite ready to hire a large Excavator so thought I would hobble together a winch to try and move some boulders. Since I will be pulling them down a slight incline, thinking with one or 2 pully blocks, I should be able to skid a 10,000 lb rock. My Massey only has a 30 amp alternator and the Kubota B3200 has like a 16 amp, so I am going with a couple of 110 amp hour AGMS. They were free from a UPS system so thats what I am using. I still have to clamp the batteries down. The winch has both wired remote and wireless but being Chinese made, its not likely really a 10,000 lb winch but I will find out next weekend.
/ Homemade 3 PTH Winch #3
I have been very disappointed with my electric winch work. I wish you better results. There is what is called the ;" Hospital side" to this type of work. Stay out of the rocks way.
/ Homemade 3 PTH Winch #4
I would also remember to add a hanging weight to the cables under load. You want something to keep them from slapping back at you in case a cable snaps. Of roaders use a heavy blanket or similar draped over the cable.
/ Homemade 3 PTH Winch #5
You might want to make the spades under the fairlead longer so that you can get a bigger bite and prevent the tractor for just being pulled backwards.
/ Homemade 3 PTH Winch #6
Very curious how this works out. I've been toying with the idea of building a logging winch - and the major stumbling block is trying to figure out what kind of winch to use. If an electric winch would work - that would make the whole idea seem a little more viable.
/ Homemade 3 PTH Winch #7
Ever thought of slipping a 100amp 2 wire alternator on your rear pto..???
/ Homemade 3 PTH Winch #8
I'm curious about more details of the PTO driven alternator.......
However I am totally electricity illiterate........ So keep info at that level please.
What RPM does it need to turn to be effective ??
Could you use a "one wire" GM type alternator ?? Like you would use for a wind generator ?? The kind with a built in voltage regulator ??
How would you wire it to the batteries ??
Thanks
/ Homemade 3 PTH Winch #9
Would you have room to upgrade your tractor alternator to a higher capacity one? On my Oliver I changed from a generator/regulator to a "1" wire alternator. I have a 12,000# Badlands winch which mounts to my "skidding" boom on the 3 pt hitch with an 875 amp deep cycle battery. I used an 8 gauge set of battery cables with eyelets to connect the winch & tractor batteries together. A 2 pole connector is in the cable to allow me to connect/disconnect the "boom/battery/winch" attachment quickly.
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
2018 INTERNATIONAL LT SERIES (A65643)
2018 INTERNATIONAL...
1998 Chevrolet C7500 Dump Truck (A62613)
1998 Chevrolet...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
New/Unused Wolverine 72in Quick Attach Rock Bucket (A65583)
New/Unused...
2004 Suzuki GSX-R750 Motorcycle (A64557)
2004 Suzuki...
