Homemade 2 shank subsoiler
   / Homemade 2 shank subsoiler
Got the lower pin brackets almost complete, just need to weld them in place and add some gussets.
Some more final details and the stand to go. Hopefully by Thursday I can test it but we're expecting some (very welcome) rain. We're in a very severe drought for the last couple of years.
   / Homemade 2 shank subsoiler #33
As I said before, I don't really need to go full depth.
After all the cuts and angles, my shanks ended up being 520 mm (~20.5") long. My 3 pt arms stop about 120 mm (~4.5") from the ground. So that leaves me about 400 mm (15"-ish) of actual depth.
As a rule of thumb, you need tine spacing roughly equal to the intended working depth. So you'd end up overlapping half passes to break up the full field.
The chisel must have a point edge (beveled upwards) and be at 20 to 30 degree angle, which is the optimum between draft resistance, and weight of the soil being lifted which loads the rear axle for traction. When the leg itself is at equal height as the chisel tip, it wont dig into the soil but slide on the leg.
Your legs are welded properly to the square tube, with that strip of metal extending to the vertical flanges of the tube: Often people forget that theyre concentrating a lot of force on the thin wall of a tube.
This more or less what I'm trying to achieve.
In this case, it's a Landini 2-55 with 50 HP, same weight and size as mine, pulling a 5 shank ripper about 11" to 13" deep.
   / Homemade 2 shank subsoiler #35
That is closer to a chisel plow over here. They typically can go 12” or so. Subsoiler is usually pulled 24” deep or so. These pull much harder because you are normally plowing through the hard pan at that depth. If all you want to do is about 15” then I would think your tractor will pull what you built no problem. Especially with draft control. Look forward to seeing it in action!
For the most part, I just want to break that hard layer that the tiller usually leaves. That could probably be achieved by going just 10" or so. On the other hand, I'm curious to see the tractor pulling some good load.
Before the idea of the subsoiler came up, I was checking some chisel plows and was mostly set on one of those. I even have a friend who would let me borrow his but I don't really like borrowing stuff if I can avoid it.
Then I started checking the subsoilers and the materials I had and went for it. If it doesn't work, I think I could sell it and get a 5 shank chisel plow with double springs instead.
   / Homemade 2 shank subsoiler #37
I have thought about a smaller version of a ripper roller. They do an excellent job on the big tractors. That would be fun to play around with. 😂
   / Homemade 2 shank subsoiler #38
Take a good look at the Landini. Four wheel drive is slipping. go deeper and hit hardpan...
I've said several times, I don't need to go deeper.
   / Homemade 2 shank subsoiler #40
So far I have one shank cut with only one 7" cutting disc. I expect another disc for the bigger cuts on the other shank and for the small pieces, I think I can take care of those on my old power hacksaw.
The ground force is extreme in MI clay. See the picture below.
Jacobsen three wheeler mower (A56857)
Jacobsen three...
1300 (A58374)
1300 (A58374)
Hydraulic spike driver (A56435)
Hydraulic spike...
SAKAI SV544D SMOOTH DRUM ROLLER (A52709)
SAKAI SV544D...
2017 Genie GTH-5519 (A53317)
2017 Genie...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
