homebuilt crawler
/ homebuilt crawler
I most certainly will. it should work to be able to use newer stuff to work with too..
/ homebuilt crawler
with the help of Unfinished's reply, I found these. outward appearance is uncanny. yet these seemed to be manufactured commercially. the drive train is not the same either, but I think it mightve been the inspiration for the home-builts. the main page (fourth link) shows several varieties of crawler locomotion through the years. quite interesting to look through. I wish they would bring back some of these early models.
http://s4.e-monsite.com/2011/05/20/85376167ranger-x-atv-pdf.pdf
http://s4.e-monsite.com/2011/05/20/14842252dahlco-3000-atv-pdf.pdf
http://s4.e-monsite.com/2011/05/20/52227643arnold-tractor-atv-pdf.pdf
TWO TRACKS RIGID VEHICLES, LIGHT
/ homebuilt crawler
hey, that is a neat article you found there, I see the date as 2009, I wonder if the article though is a reprint of a much earlier one.? mine here is so closely resembled, I would think at first guess that it is a copy of one of these. this manufactured one being a clutch pedal style, would seem like a good idea. I wonder who evolved mine into the centrifugal clutch. not a great leap of imagination actually. mine is a home built alright, with chev and jeep parts into the drive train, but it seems logical that it very well was inspired by the manufactured version.
/ homebuilt crawler #26
HEy, I would like to build something like that myself, but with a PTO worked in somewhere. Problem is I dont know where to start. Any pointers anyone?
/ homebuilt crawler #29
Did a quick image search and found a couple pictures awfully similar.
From this page
Route6x6 Photo Gallery
"An unknown reader send in pictures of an OTTER "1972 Ferret with plow and hydros.PHOTO the one with a cab has 2 foot wide tracks and is a one af kind. the other PHOTO of a 1966 ranger" Looks a bit commerical to me! Thanks"
I have one of these rangers. Word of mouth,they were built in Pengilly, Minn. in the 40's had Crosley parts and mine had a 2o hp engine. I am looking fro a clutch yoke now. Yes it is a nice little woods tractor and fairly good in the snow.. apparently they like them in Alaska. I would appreciated any aid in finding the part.
/ homebuilt crawler
I suppose you could have a machine shop fab you a new one patterned off the old one? mine didnt have that kind of clutch in it, it had/has a centrifugal clutch between the engine and tranny. shifting gears was no problem , as there were no rpm's active while gear selecting.
I had sold mine about a year ago sorry to say, or i could get you some close up photos of the clutch inline. i seem to remember it was a sprocket off the end of the centrifugal clutch, drive chain going to a sprocket on the tranny input. that part worked just fine.
Den
/ homebuilt crawler #31
that looks like a great project. With a 4sp tranny with pto window, hyd pump and hyd motor to the input shaft of the tranny, forward reverse in every gear would be an easy fabrication. This one I have to get on the drawing board
/ homebuilt crawler #32
What a fun build that would be. Running a hyd pump with a hyd motor on the input of a 4sp tranny with a pto window would be an easy way to go. Might have to put a radiator with fan for oil cooling, but could be made to be a compact unit. A fun one to say the least.
/ homebuilt crawler #33
Still dreaming about this. They use motorcycle engines to race small legend cars. Hook a driveshaft direct to the rearend. With this a clutch would be already there, a 5-6 speed in front of a 4sp would sure give some low gearing. Just a thought.
KL480 Ventrac tiller
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
Bobcat 72SDR Seeder (A66285)
Bobcat 72SDR...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2020 INTERNATIONAL...
New Landhonor LHR-COA200,  200lb Cast Iron Anvil (A62679)
New Landhonor...
Gehl RS6-34 (A64119)
