Comparison Home Stand By Generators
/ Home Stand By Generators #281
I have a GE 20kw whole house generator, it's 8 feet away from the house.. it's pretty quite.. I'm happy with it.. it almost a year old..
Welcome! Is your GE a Generac clone? GE doesn't build small gas motors, so usually a Kohler uses a Kohler Engine and a Generac uses a Generac engine which is pretty much a Vanguard clone perhaps with some minor enhancements. I know that Generac went into rebranding a few years ago.
My Generac 20kw was flawless and that's why I'm considering the latest 22kw version.
/ Home Stand By Generators #282
I know it's a Generac clone with a 5 year warranty. it's made with a BS engine.
/ Home Stand By Generators #283
generac enclosures are UL rated for installation 18" from house..... its LISTED. you can always place them further if you want. also propane co here wants 10' distance from tank and building codes require 5' min clearance from any opening into house.
ive services generac units 15 years old and still working great. if there maintained, they just keep working.
adjust the valve lash after the first 50 hours is a big helpo
/ Home Stand By Generators #284
/ Home Stand By Generators #285
I purchased a Generac whole house unit Generac Guardian 22kW Standby I paid to have a 250 gallon propane tank and have it buried. Gas line piping, electrical circuit breaker box rewiring and a transfer switch. The installation was inspected and completed to code. It works flawlessly. Best $8000 I've ever spent. I can't power the entire house as we have 2 air conditions and I can't power the workshop. But when the power fails, (a total of 6 times this last summer). We have lights, the fridge, water from the well, freezer, air conditioning, washer and drier. The tank size was selected to provide me power for 9 days without a refill. I can safely say it paid for itself this last summer we actually received an apology letter from the power company because of the number of times we experienced power outages.
/ Home Stand By Generators #286
Considering whole house BU LP generator. ~22kw would work for me. If I might ask, what is a fair total amount, wright a check and done, for the generator, burried 250 tank, plumbing, electrical, etc? Thank you...
/ Home Stand By Generators #287
"provided it is located away from doors, windows, and fresh-air intakes, and unless otherwise directed by local codes.
/ Home Stand By Generators #288
"Provided it is located away from doors, windows, and fresh-air intakes, and unless otherwise directed by local codes."
/ Home Stand By Generators #289
My uncle built a concrete block "Bunker" for his genset 25 years ago and it has worked out well... plenty of circulation and combustion air and it is not going to burn because even the roof is concrete with sod on top.
Sounds like he did a nice job on it.
/ Home Stand By Generators #290
that would be nearly impossible to set as a complete price. Ive now installed 16 of these units over the past few months, and everyone has been different. Different panel loads, some need load shedding, some dont. Some are close to power and gas, some need new tanks installed. Electrical hookup can take from 6 hours to 24 hours to install.
i can say the prices have ranged from $5,800 - 9,000 for a 22KW... complete.
/ Home Stand By Generators #291
I have a question about adjusting the valve lash on a Generac/Vanguard engine.
Does the Generac approved installer actually know how to do that or is he "just an electrician"?
Since when did electricians adjust valves? So then, who to get that will do it competently and actually come out to your home? I'd be worried about someone leaving it worse than he found it if he has little experience doing this.
One of the things not mentioned here is the exhaust heat of these units. I melted a six foot area of garden flowers when the unit ran during an outage and not just on test. Higher rpm under pretty full load, lot more heat getting pumped out, make sure nothing is living within six feet of that exhaust end or your local gardener is not going to be happy.
/ Home Stand By Generators #292
Thank you Sir now I feel a little bit better about my installation. My Generac was install by the book, rules and regulations. 18" from a wall and 10' from the tank and the distance required from windows, air inlet etc. Maybe I will move the tank away from the house to ease some people around here who think it is too close to the generator. Thanks again for your positive response.
/ Home Stand By Generators #293
Not sure if the installer should be the one to adjust your valves but I am sure some are very mechanically inclined to do so. I know my installer will come and do the maintenance when required but no need as I am capable of servicing my own. I have been doing my own small engine repairs for years and these generator engines are just that.
Valve adjustments are relatively easy to do especially on engine where the head valves are positioned at the front of the engine and at easy access. All you need is a wrench, valve gauge and the owners manual or go online and see a video on how to do it.
As for the distance of any objects or vegetation should me 10' or more away from the exhaust.
/ Home Stand By Generators #294
In my case the dealer/installer was only allowed to do just that. Generac has to certify (?) the mechanical side of it. The dealer that installed mine was only able to work on the electrical side of it. He had even requested Generac to train/certify him on the mechanical aspects, but request was rejected. My mechanical service has to come from 60 mi away (charge mileage both ways) which is stupid on Generac's part. I even sent them a nasty email about that, but got no response back.
My advise is, whatever brand you purchase, make sure that the dealer/store can provide complete service if you ever need it.
/ Home Stand By Generators #295
I just checked with my Generac dealer and he says that his company is certified by Generac to do all maintenance and repairs on their generators. Bonus to know.
/ Home Stand By Generators #296
generac certifies the installers (whoever they are) after a 3 day hands on class in air cooled generator service.
/ Home Stand By Generators #297
We are a what Generac calls a "Elite Dealer service center" We have been trained on propane units up to 150 kw..
There are lots of installers out there but never service what they sell :(
/ Home Stand By Generators #298
/ Home Stand By Generators #299
I've thought about a stand-by generator, but the portable one I got has been so much more useful. I use it mainly to run power tools (like table saws) or my welder that don't run well in the barn. Previous owners only ran a single 110v line to the barn, and everything is run through a single light switch. :rolleyes: I bought a bigger air compressor to use out there, and it trips the overload switch on the motor without even spinning up so that's in the basement now with 120ft of air hose.
I've also loaned it to inlaws during a 3 day outage, a co-worker that lost power during the 2011 flood, and another co-worker that needed to power tools and pumps at his house after the 2011 flood went 2ft up his walls. So really, other people have used my generator more than I have! :laughing: My inlaws bought their own shortly thereafter so I don't have to let the borrow it anymore.
/ Home Stand By Generators #300
2017 Ford Escape SUV (A61569)
2017 Ford Escape...
30 Yard Dumpster (A61166)
30 Yard Dumpster...
Rogator RG1100 (A63118)
Rogator RG1100...
2000 DODGE RAM 3500 EXTENDED CAB DUALLY TRUCK (A62130)
2000 DODGE RAM...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2015 John Deere 8345RT Track Tractor (A63109)
2015 John Deere...
