Comparison Home Stand By Generators
/ Home Stand By Generators #243
Sometimes it is not limited to homeowners.
I bought a few acres and within a week received notice on non-compliance... brush was to be cut including vegetation over 6" and trees limbed below 6 feet.
It was under threat of escalating fines and I could get no where with the inspection dept.
Went to City Council and spoke during the open forum... I said I would be do whatever the city wanted... only needed to know if the city actually wanted me out there with power equipment during the reg flag fire watch days of summer.
Told them I was new owner and after a conference city decided I was OK to wait until the red flag warning was over...
City people only go by calender dates... they know little to nothing about weather and site conditions...
/ Home Stand By Generators #244
When thinking of safety the possibility of auto start with no one at home is often overlooked.
A local family lost their home when the genset started automatically... the flames spread from the wooden structure and because the home was partially hidden, flames spread to the home.
Rodents had built a nest and the family was away for Thanksgiving when a branch took out power to their home.
A truly automatic system is just that... it will start and run until it can't, someone manually turns off the power or power is restored.
So the generator was in a wooden structure ???
/ Home Stand By Generators #247
Here's an article that contains a list of many people that died during hurricane Sandy within a 65 mile radius of New York City. 15 people died from carbon monoxide poisoning from generators.
4 people died from electrocution, but none involved generators.
Still doesn't mean we shouldn't use proper safety precautions, but does make you realize the biggest home generator danger is from carbon monoxide poisoning by a huge factor.
The People Who Were Killed By Hurricane Sandy | Whitney Hess
/ Home Stand By Generators #248
one of the real downsides of a portable gen is how to run in the pouring rain or blowing snow when you don't have a convenient overhang to park it under. I won't even run mine in my garage with the doors open. Never know where that CO2 will wind up; always run it outside, at my last house under the totally open front entrance porch. At this home, I don't know yet, will have to be out the garage back door, which then gives my extension cords a straight shot into the kitchen.
So what happens when a gas powered generator is operated outside in the pouring rain for several hours?
/ Home Stand By Generators #249
there is no cheap way haha. i have a program from generac to calc generator loads. its part of my powerplay software. i use it when i size my jobs.
If theres elect heaters...theres always problems. When i get houses with electric backup heaters and or electric water boilers, i always need to shed those loads....unless i go big.
i reciently hooked up a 45KW unit on a house with electric heat, elect backup heat, elect water heaters and heat pumps. took some doing. It works great though. On this application, he had 2 x 200 amp panels so i installed 2 x 200 amp transfer switches and joined the feeds together in 16x16 J box with single 200 amp feed to generator.
care has to be taken to link both switches EXACTLY the same. i use color coded wires .... it gets confusing at times.
Very nice job. I sure wish you were closer to me. I would like to get your thoughts on my set up!
/ Home Stand By Generators #250
Good question.... I've always run mine in our unattached shed with the door open. I ran it in my in-laws in a yard barn with the door open. I guess that's something that needs to be planned for before it happens. If its pouring rain, you probably shouldn't be messing with a generator anyway. Good way to get whacked. :shocked:
/ Home Stand By Generators #251
Honda Generators - Generator Operation
Keep the generator dry.
Do not use the generator in wet conditions, such as rain or snow, or near a pool or sprinkler system.
I can't say for other brands, but Hondas are not rain ready. My Honda gen. doesn't like to get wet, the engine starts missing.
/ Home Stand By Generators #252
It is a necessary safe practice to ground every generator well. All have a grounding lug and I have driven two 8' electrical ground rods and connected a braided copper wire to the grounds with copper connectors and then to the generator lug. This must be done to insure that all the connected loads are grounded and safe.
/ Home Stand By Generators #253
I've wondered about this because I have a truck mounted unit that I use for grinders and drain rooter machines... the generator is bolted to the truck... the truck sits on tires... nothing is driving into the ground.
/ Home Stand By Generators #254
Yeah, makes you wonder about all those portable generator/welder sets you see on service trucks. Does anyone really ground them? :confused:
/ Home Stand By Generators #255
That's the story of my life... living on the edge...
Speaking of grounds... and off topic.
Mom was having a hard time keeping the critters out of her vegetable garden even with the cyclone fence I put in.
Next step was to add a hot wire which worked ok in the winter... stopped working during the California drought... so I added a ground wire from the fence charger to the metal fence... talk about an electric fence... nothing climbs up and over anymore.
Next problem is mom would forget and was always getting shocked.
So I put the charger on a timer and all is good... only time the critters would attack the garden was under cover of darkness...
Moral... Proper use of grounds is important!
/ Home Stand By Generators #256
and grounds maintenance :D
and I enjoy making coffee grounds too :stirthepot:
/ Home Stand By Generators #257
CO2 is a minor hazard compared to how lethal CO is.
/ Home Stand By Generators #259
Getting back to the original question, what is the best standby generator? I see a lot of people here with Generac/guardian generators, but when I was buying mine I was told to stay away from them because they're not reliable. What have your experiences been?
/ Home Stand By Generators #260
I very much doubt that the major generator manufacturers would knowingly put out a product that wouldn't hold up to use. That being said, my Kubota has been great and very reliable to date. The only non-start issue has been a low battery in the middle of winter - I now keep two batteries there.
I expect what you were told is basically BS and don't buy from the competition for whatever reason.
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
Dexter trailer axles (A61567)
Dexter trailer...
DELTA RADIAL ARM SAW W/ ELECTRIC BRAKE (A62131)
DELTA RADIAL ARM...
UNUSED 2026 INDUSTRIAS AMERICA 5'X10' HYD DUMP TRL (A62130)
UNUSED 2026...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
