Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame
Interesting - over here I would not expect liquid cooling on a 2 wheel tractor; but I have seen enough of your work now to picture you adding your own liquid cooling if it was not original.
I know how critical the acoustic enclosure design is for piezo drivers (for alarms) - that is neat what you did with the funnel.
Rgds, D.
Thank you!:)
The factory cooling was not enough.
   / Home-made mini tractor 4*4 with the joint joined frame #82
Vladimir, you not only have a tractor superbly sized and outfitted for your size operation, but have shown us more images of your actual farming activities than anyone else I can think of...at least for a long time...I have greatly enjoyed observing your farming methods as well as noting that your land is in excellent shape for growing crops. Well done!:drink:
Enormous thank you! And earth for us is excellent, but also working is needed well.:)
Verification of making home-made slots in a year operation
   / Home-made mini tractor 4*4 with the joint joined frame #85
Wow, excellent craftsmanship, thanks for sharing... :thumbsup:
   / Home-made mini tractor 4*4 with the joint joined frame #87
Your English is not as good as it could be, but there is no question about your workmanship.
Any one that doubts you should be slapped with a wet fish.
   / Home-made mini tractor 4*4 with the joint joined frame #88
I can figure out what you are saying.
It is exact! Were and those which doubted :)
2019 International DuraStar 4300 24FT Box Truck (A56858)
2019 International...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2014 Freightliner M2 106 5.1Yds Asphalt Pot Hole Patcher Truck (A56858)
2014 Freightliner...
Groundsmaster 3500-D madel 30839 (A56859)
Groundsmaster...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
