Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame
Interesting - over here I would not expect liquid cooling on a 2 wheel tractor; but I have seen enough of your work now to picture you adding your own liquid cooling if it was not original.
I know how critical the acoustic enclosure design is for piezo drivers (for alarms) - that is neat what you did with the funnel.
Rgds, D.
Thank you!:)
The factory cooling was not enough.
   / Home-made mini tractor 4*4 with the joint joined frame #82
Vladimir, you not only have a tractor superbly sized and outfitted for your size operation, but have shown us more images of your actual farming activities than anyone else I can think of...at least for a long time...I have greatly enjoyed observing your farming methods as well as noting that your land is in excellent shape for growing crops. Well done!:drink:
Enormous thank you! And earth for us is excellent, but also working is needed well.:)
Verification of making home-made slots in a year operation
   / Home-made mini tractor 4*4 with the joint joined frame #85
Wow, excellent craftsmanship, thanks for sharing... :thumbsup:
   / Home-made mini tractor 4*4 with the joint joined frame #87
Your English is not as good as it could be, but there is no question about your workmanship.
Any one that doubts you should be slapped with a wet fish.
   / Home-made mini tractor 4*4 with the joint joined frame #88
I can figure out what you are saying.
It is exact! Were and those which doubted :)
2020 DRAGON ESP...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
1995 Ford 3930 50HP Utility Tractor w/ Land Pride RCD1884 84in. Brush Cutter (A55973)
1995 Ford 3930...
Landoll Lowboy Trailer (A56435)
Landoll Lowboy...
2021 Ford F-150 (A55973)
2021 Ford F-150...
