Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame #71
Thanks for all of your videos. Your craftsmanship is amazing.
   / Home-made mini tractor 4*4 with the joint joined frame #73
Definitely a thread I will have to come back too. Lots of great idea in just the first video I watched.
Additional panel of devices
   / Home-made mini tractor 4*4 with the joint joined frame #76
6 volt system - correct ? Nice big alternator and battery.
The white plug you show sitting on the left side of the panel - is that for supplying power to someting external to the tractor, or are you using it as a shorting shunt ?
I like that phone cable routed on the control rod.
With your lights, you'd be more road-legal than most ATVs that run around here !
The external tank beside the battery - what is in that ? What are those 2 lines in the red funnel ?
Looking good :thumbsup:
Rgds, D.
   / Home-made mini tractor 4*4 with the joint joined frame #77
Amazing Machine,good Job
Rgds, D.
There 12 volt, a voltmeter is megascopic a resistor.
White shteker for the lamp of external illumination.
External tank for expansion of cooling liquid
There are voice Warners of turns in a red crater. Funnel is strengthened by a sound
   / Home-made mini tractor 4*4 with the joint joined frame #80
Interesting - over here I would not expect liquid cooling on a 2 wheel tractor; but I have seen enough of your work now to picture you adding your own liquid cooling if it was not original.
I know how critical the acoustic enclosure design is for piezo drivers (for alarms) - that is neat what you did with the funnel.
Rgds, D.
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
2017 Ford F-750 Crew Cab Terex Hi-Ranger 6TC-65 65ft Insulated Bucket Truck (A56858)
2017 Ford F-750...
WATER TRAILER (A58214)
excavator trenching bucket- one bucket per lot (A56435)
excavator...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
