Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame #71
Thanks for all of your videos. Your craftsmanship is amazing.
   / Home-made mini tractor 4*4 with the joint joined frame #73
Definitely a thread I will have to come back too. Lots of great idea in just the first video I watched.
Additional panel of devices
   / Home-made mini tractor 4*4 with the joint joined frame #76
6 volt system - correct ? Nice big alternator and battery.
The white plug you show sitting on the left side of the panel - is that for supplying power to someting external to the tractor, or are you using it as a shorting shunt ?
I like that phone cable routed on the control rod.
With your lights, you'd be more road-legal than most ATVs that run around here !
The external tank beside the battery - what is in that ? What are those 2 lines in the red funnel ?
Looking good :thumbsup:
Rgds, D.
   / Home-made mini tractor 4*4 with the joint joined frame #77
Amazing Machine,good Job
Rgds, D.
There 12 volt, a voltmeter is megascopic a resistor.
White shteker for the lamp of external illumination.
External tank for expansion of cooling liquid
There are voice Warners of turns in a red crater. Funnel is strengthened by a sound
   / Home-made mini tractor 4*4 with the joint joined frame #80
Interesting - over here I would not expect liquid cooling on a 2 wheel tractor; but I have seen enough of your work now to picture you adding your own liquid cooling if it was not original.
I know how critical the acoustic enclosure design is for piezo drivers (for alarms) - that is neat what you did with the funnel.
Rgds, D.
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
UNUSED FUTURE FT-RR78 - 78" HYD ROCK RAKE (A52706)
UNUSED FUTURE...
2018 CATERPILLAR 289D SKID STEER (A52709)
2018 CATERPILLAR...
2014 JOHN DEERE  544K WHEEL LOADER (A58214)
2014 JOHN DEERE...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
2016 Peterbilt 337 Corrosive Flammable Liquid Transport Truck (A55973)
2016 Peterbilt 337...
