Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame
Interesting - over here I would not expect liquid cooling on a 2 wheel tractor; but I have seen enough of your work now to picture you adding your own liquid cooling if it was not original.
I know how critical the acoustic enclosure design is for piezo drivers (for alarms) - that is neat what you did with the funnel.
Rgds, D.
Thank you!:)
The factory cooling was not enough.
   / Home-made mini tractor 4*4 with the joint joined frame #82
Vladimir, you not only have a tractor superbly sized and outfitted for your size operation, but have shown us more images of your actual farming activities than anyone else I can think of...at least for a long time...I have greatly enjoyed observing your farming methods as well as noting that your land is in excellent shape for growing crops. Well done!:drink:
Enormous thank you! And earth for us is excellent, but also working is needed well.:)
Verification of making home-made slots in a year operation
   / Home-made mini tractor 4*4 with the joint joined frame #85
Wow, excellent craftsmanship, thanks for sharing... :thumbsup:
   / Home-made mini tractor 4*4 with the joint joined frame #87
Your English is not as good as it could be, but there is no question about your workmanship.
Any one that doubts you should be slapped with a wet fish.
   / Home-made mini tractor 4*4 with the joint joined frame #88
I can figure out what you are saying.
It is exact! Were and those which doubted :)
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
500BBL WHEELED...
24in pin on tooth excavator bucket (A56435)
24in pin on tooth...
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
