Home Generator Recommendations.......
/ Home Generator Recommendations....... #1
Junkman
Super Member
North East CT
2003 Kubota BX-22
I am looking for recommendations of a generator to replace the existing one. My requirements are 8 to 12KW, 1800 RPM, diesel. No enclosure needed since it is going to be mounted in the garage and there is no need for a fuel tank since it has a diesel fuel pick up located in the garage. A "hospital quiet" muffler system is a plus if available. Prefer a Lister-Petter or Kubota engine if possible. Manual start and run, since it will be wired into a 200 amp generator disconnect switch.
/ Home Generator Recommendations....... #2
I had the same requirement and here is what I did:
click for link
I really wanted a water cooled 1800 RPM unit, but couldn't see the additional cost. I actually "shopped" for over a year. These units are $ 4000 on up, unless you are willing to buy a high-hour mil surplus unit. My interest was in something fairly new and reliable, with easy to find parts if required. I ended up buying an air cooled 3600 RPM unit. It is a step down in life and noise, but I rationalized that since it is 100' from the house in the shed, noise was not a driving issue, and since it was for backup duty, life of an aircooled unit would suffice. I compromised on my goals, but I am quite satisfied with what I have.
Last week we had a power outage at 10:00 PM on Friday. It was 5 deg out. I waited a bit to make sure that it was not a short outage. I hopped in the car to take a look-see, since the substation is only a few miles away, faults are usually local. Sure enough an SUV plowed through a pole and into a house. Wires alll over the ground. I cranked up the genset (two quick shots of ether were needed due to the cold temps. The house had lost 4-5 deg in the 30 minutes of outage. I ran my 3 heat pumps as well as normal lighting, TV, computers, etc. The power was out 8 hours and we kept nice an warm, as the temp dropped to -5 deg that night. I'm sure some of the neighbors were not as comfortable. I was very pleased to see that I only consumed 3 gallons of diesel over 8 hours, with about my worst case load.
It's too bad you didn't post a week or 2 ago. A guy at work just sold a 15KW unit with a Kubota engine (3600 RPM however), in a doghouse and integral tank and control panel, for $ 2000. Very low hours as well. I almost bought it, but I felt what I had was sufficient for my needs, and it would need to sit outside, a negative wife factor.
You might want to check with these guys:
http://www.centralmainediesel.com/order/ES12000D.asp?page=ES12000D
They have a good selection at what is reasonable prices. I linked one particular model, but they have a wide range available. I also found that in general, eBay rarely has good deals for "nice" units. Also based on many examples I have read stay far away from the Chinese imports. For example:
http://gpsinformation.net/chinagen.htm
Gool luck in your hunt.
paul
EDIT: I shortened the text for the link.
Thanks for the information. I will check out that site. If you hear of another such deal like that one, please let me know. That one would have been perfect for my use.
2025 GIDDY UP 7'X14' BLACKOUT XTREME CARGO TRAILER (A62130)
2025 GIDDY UP...
2012 Mini Cooper Coupe (A61574)
2012 Mini Cooper...
SHOP FANS AND MIRRORS (A63569)
SHOP FANS AND...
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
Ag Leader Integra Screen (A63116)
Ag Leader Integra...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
