Hobart Plasma
/ Hobart Plasma #1
Big Bri
Platinum Member
Kubota MX5100
are these any good for home shop, a friend of mine wants to sell me his airforce 625 for $800. He only had for 6 months,It looks pretty new, he told me he didn't use it much. I just don't want to buy it if it is junk.
Thanks
Brian
/ Hobart Plasma #2
Im not sure of the model you are looking at but I have the 220V hobart plasma and love it. Works great and saves me a lot of work!! I paid about $1100 for mine new
/ Hobart Plasma
Thanks, i've never used a hobart before and didn't know how good they were.
you say yours is 220 volt, do you know what model? i just wondering if you got yours for 1100, might be worth the extra 300 and buy new. . . or maybe try to talk him down some.
thanks
/ Hobart Plasma #4
I'd look up the specs on hobarts web sit and see if it's capable of what you'll be doing with it. I don't own one yet because the one I want is about 2 grand. But I have used them enough to know a smaller one would be almost useless for myself.
/ Hobart Plasma #5
I have an Airforce 400 and love it. Haven't had any problems at all. We have the Miller version of the 625 at work and it is great too.
/ Hobart Plasma #6
Thanks
Brian
It list for about $1699. It is in the 40 amp range of plasma cutters. Maybe cut 3/8 in. What most people don't consider is that 40 amps is doing about the same thing as the name brands. I have a Lincoln 25, and a 55 amp plasma cutter. As long as you have the amps and good clean air, I don't think you can tell which machine cut a certain piece of steel. I paid $2500 for my Pro-Cut 55, but I could not swear that it was the best. It does what I want it to do. I have purchased a machine torch for it to use on my plasma cutting table.
Hobart 500493 - Airforce 625 Plasma Cutter
/ Hobart Plasma
thanks for all the info, i think i'm going to buy it. will talk to him when he gets off work tonight.
thanks again
Brian
/ Hobart Plasma #8
Here is something nice to have for a plasma cutter. It has two things on it. a hole cutter, and the wheels to keep it off the steel and guide you along a straight edge.
Plasma Cutting Guide
/ Hobart Plasma #9
I think it depends entirely on the condition of the plasma.
/ Hobart Plasma #10
thanks
$800 for a $1700 machine that is six months old and you want to talk him down? That is an awesome machine for that price. If it is only 6 months old he probably still has the receipt.
You can cut 1", you wont get a nice FLAT cut (it will be concave), but you will get a clean cut. You will breeze through 1/2" no problem. I get pretty good cuts on 3/4" with my Powermax 600 (a 40 AMP machine). Just knock the slag off with a hammer. I still need to grind if I want to remove the torch marks. Finding the right hand speed, and then getting nice smooth movement is key, something I'm not always able to do.
I will say this, I wish I had a bandsaw instead of my plasma. While I have used my plasma to cut angle and tube, you just can't do as nice a cut as a bandsaw will do. The plasma is great for flat bar and sheet, but if you want to cut a lot of tube and angle a bandsaw will be a better purchase.
/ Hobart Plasma #13
JJ, glad to see someone finally started making the cutting torch roller guide. About 35years ago, I made a similar roller guide for an OA torch from a 3/4" 2H nut and 2 cutting wheels from a pipe cutter. I just tackwelded the axles to the nut, drilled and tapped the nut for in a set screw that tightened on the cutting tip. It worked like a charm and took all of 30 minutes to make.
/ Hobart Plasma
well i screw up big time. i started reading about different plasma torches and was starting to wonder if i should buy this one or order a different one. by the time a figured that at this price ans for how little i would use it that it was better to buy the used hobart than to buy a new Thermal Dynamics torch(which i liked every thing i read about except the price $1499) so when i go to buy the hobart i'm told that he already sold it. . .i hate over thinking things.
(3) JOHN DEERE DRY FERTILIZER DISTRIBUTORS (A64278)
(3) JOHN DEERE DRY...
2011 GMC Acadia SUV (A64557)
2011 GMC Acadia...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
1996 Aspen T/A Pump Trailer (A64194)
1996 Aspen T/A...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
HONDA Plate Compactor (A64553)
HONDA Plate...
