Hobart Plasma
/ Hobart Plasma #1
Big Bri
Kubota MX5100
are these any good for home shop, a friend of mine wants to sell me his airforce 625 for $800. He only had for 6 months,It looks pretty new, he told me he didn't use it much. I just don't want to buy it if it is junk.
Thanks
Brian
/ Hobart Plasma #2
Im not sure of the model you are looking at but I have the 220V hobart plasma and love it. Works great and saves me a lot of work!! I paid about $1100 for mine new
/ Hobart Plasma
Thanks, i've never used a hobart before and didn't know how good they were.
you say yours is 220 volt, do you know what model? i just wondering if you got yours for 1100, might be worth the extra 300 and buy new. . . or maybe try to talk him down some.
thanks
/ Hobart Plasma #4
I'd look up the specs on hobarts web sit and see if it's capable of what you'll be doing with it. I don't own one yet because the one I want is about 2 grand. But I have used them enough to know a smaller one would be almost useless for myself.
/ Hobart Plasma #5
I have an Airforce 400 and love it. Haven't had any problems at all. We have the Miller version of the 625 at work and it is great too.
/ Hobart Plasma #6
Thanks
Brian
It list for about $1699. It is in the 40 amp range of plasma cutters. Maybe cut 3/8 in. What most people don't consider is that 40 amps is doing about the same thing as the name brands. I have a Lincoln 25, and a 55 amp plasma cutter. As long as you have the amps and good clean air, I don't think you can tell which machine cut a certain piece of steel. I paid $2500 for my Pro-Cut 55, but I could not swear that it was the best. It does what I want it to do. I have purchased a machine torch for it to use on my plasma cutting table.
Hobart 500493 - Airforce 625 Plasma Cutter
/ Hobart Plasma
thanks for all the info, i think i'm going to buy it. will talk to him when he gets off work tonight.
thanks again
Brian
/ Hobart Plasma #8
Here is something nice to have for a plasma cutter. It has two things on it. a hole cutter, and the wheels to keep it off the steel and guide you along a straight edge.
Plasma Cutting Guide
/ Hobart Plasma #9
I think it depends entirely on the condition of the plasma.
/ Hobart Plasma #10
thanks
$800 for a $1700 machine that is six months old and you want to talk him down? That is an awesome machine for that price. If it is only 6 months old he probably still has the receipt.
You can cut 1", you wont get a nice FLAT cut (it will be concave), but you will get a clean cut. You will breeze through 1/2" no problem. I get pretty good cuts on 3/4" with my Powermax 600 (a 40 AMP machine). Just knock the slag off with a hammer. I still need to grind if I want to remove the torch marks. Finding the right hand speed, and then getting nice smooth movement is key, something I'm not always able to do.
I will say this, I wish I had a bandsaw instead of my plasma. While I have used my plasma to cut angle and tube, you just can't do as nice a cut as a bandsaw will do. The plasma is great for flat bar and sheet, but if you want to cut a lot of tube and angle a bandsaw will be a better purchase.
/ Hobart Plasma #13
JJ, glad to see someone finally started making the cutting torch roller guide. About 35years ago, I made a similar roller guide for an OA torch from a 3/4" 2H nut and 2 cutting wheels from a pipe cutter. I just tackwelded the axles to the nut, drilled and tapped the nut for in a set screw that tightened on the cutting tip. It worked like a charm and took all of 30 minutes to make.
/ Hobart Plasma
well i screw up big time. i started reading about different plasma torches and was starting to wonder if i should buy this one or order a different one. by the time a figured that at this price ans for how little i would use it that it was better to buy the used hobart than to buy a new Thermal Dynamics torch(which i liked every thing i read about except the price $1499) so when i go to buy the hobart i'm told that he already sold it. . .i hate over thinking things.
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2009 Ford Escape SUV (A64557)
2009 Ford Escape...
Kubota L3901HST
Kubota L3901HST
