Hobart handler 135
/ Hobart handler 135 #1
redharley
central, Pa
BX2230
I have had this for some time now ran out of wire last I used it for might needed it tonight out of gas , put Flux wire on switched power leads as shown in manual. Welds great but has power to tip as soon as it's plugged in. Turning power switch on allows wire to advance. Sound right or do I need to change something else.
/ Hobart handler 135 #2
There should be no welding current unless you have the mig gun trigger depressed. There will be a small residual amount after letting go of the trigger, enough to cause a spark, but that should be all it does.
/ Hobart handler 135 #3
It shouldn't be doing that. Your contactor is probably stuck.
Terry
Thanks for with info will try an see if I Can get it ton work. Never reversed polarity before to use with Flux core. Worked OK when set for might welding.
/ Hobart handler 135 #5
Did you switch the roller also?
/ Hobart handler 135 #6
FYI. Check out this board. Sign up speak your piece and maybe one of the regulars will advise you. Also , this site is monitored by Hobart techs so one of them may help you out. It's a pretty quiet site lately but still worth a shot. Also do a search there. I seem to remember years back a couple guys posing that same question.
/ Hobart handler 135 #7
Check if the gun switch is stuck on. You should be able to hear it click with the machine off. Could be a stuck contactor too. Probably not the case but have seen this problem when someone had the gun sitting on the trigger.
2015 KOMATSU PC170LC-10 EXCAVATOR (A62129)
2015 KOMATSU...
2008 BMW 535xi AWD Sedan (A59231)
2008 BMW 535xi AWD...
2002 Miller Trailblazer 301G Towable Welder Generator (A59228)
2002 Miller...
2004 Mitsubishi Endeavor AWD SUV (A59231)
2004 Mitsubishi...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
2012 Ford F-550 4x4 Terex Hi-Ranger LT40 40FT Insulated Bucket Truck (A59230)
2012 Ford F-550...
