Hitting all the common BX problems
/ Hitting all the common BX problems #62
Is the Kubota Kit K2561-96140 fixing the Gas Tank Leaking over the left Rear. I just purchased my used BX 1800 from local dealer only to find out that I can not use it until I get this leak fixed. What is the solution to the leak?
Thanks in Advance!!
/ Hitting all the common BX problems #63
Hi Tom,
On the throttle not staying at high, the fix is easy.
Take off the black u-shaped grill under the steering column.
Find the double-nut setup on the throttle bolt and tighten as you please.
It worked for me.
Thanks,
Steve
2010 Dodge Grand Caravan Van (A64557)
2010 Dodge Grand...
FORD 3 BOTTOM PLOW (A64278)
FORD 3 BOTTOM PLOW...
2011 GENIE Z-45/25 TELESCOPIC BOOM LIFT (A65053)
2011 GENIE Z-45/25...
2025 JOHN DEERE 333P SKID STEER (A65053)
2025 JOHN DEERE...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2007 Ford F-750 Chipper Truck (A64194)
2007 Ford F-750...
