Hitting all the common BX problems
/ Hitting all the common BX problems #1
upgw
SE PA
2001 Kubota BX2200, 2011 Hustler Super Z 31 Kawi
Moving chips, got a strange sound from under the hood, yup, the braket strap for the air cleaner is broken. Dealer says it's a 'kit' not just a new strap. They are coming to get it, and I've also asked them to work on the partially frozen HST pedal.
I see the common problems as:
1) Fuel tank leak (fixed that)
2) Hood rattle (alright, minor)
3) HST pedal sticking (not at the shaft, that's free)
4) Steering loss due to internal leakage
5) Broken air cleaner strap
Have not seen #4 yet.
- Patrick
/ Hitting all the common BX problems #2
Fuel level gage reads eratic...I think that is another one...
/ Hitting all the common BX problems #3
Two more: 1) PTO clutch engages very abruptly 2) My throttle won't stay set at the high end, it just slips back down into mid-range. Anyone else had problems with that one?
/ Hitting all the common BX problems #4
hst pedal is in the cradle bearings in the tractor.......dont ask me where they just are. that is what the dealer had to change to fix mine. he had to get in touch with Kubota on it before they "realized" what it was
/ Hitting all the common BX problems #5
Tom-H,
There's a lock nut under the dash that you can tighten for the throttle lever. Ever tried that? My throttle was a little too loose for my liking and I just adjusted the nut a couple of times until the 'feel' of the lever was just tight enough to prevent slipping, but loose enough so that I could easily make fine adjustments on the engine speed.
roger
/ Hitting all the common BX problems #6
My additions to list:
1) had to replace all hydraulic hoses over a ~6 month period due to pin-hole leaks developing. I'm convinced it was a defective Lot of hose. Most leaks were in protected areas with NO visible physical damage. I'm guessing there was a rash of problems with these hoses because a couple of them were back-ordered at Kubota and it took 3 weeks to get them in.
2) Sometimes the hydro tranny will not spin the wheels (like when trying to pull a stump or other immovable object). Yes, I know about the effect of pushing the pedal all the way down.
There are several posts on this issue with several folks complaining of the same problem. Not a real big issue for me, so I have never done anything about it.
3) Temp. gage showing 3/4 scale hot when mowing. Several posts on this one. At the advice of my dealer, I removed the thermostat last summer and ran without it. No temp. change. I recently ordered a new temp. gage and sender 'cause I'm convinced the engine is not really running hot. Unfortunately, life keeps getting in the way and have not had time to install it.
roger
/ Hitting all the common BX problems #7
Tell me more about the fuel leak....I have one too but only with a full tank and bouncing the tractor a lot...is it the tank or a hose clamp?
/ Hitting all the common BX problems #8
I believe that they have a problem with the sending unit leaking. I'm putting mine in the shop in a couple weeks. I was told this would be covered under warranty.
Dave
/ Hitting all the common BX problems #9
I just recently developed a fuel leak too...but I quickly found the source. There's a fuel hose that wraps around the back of the tank and enters the tank just under the fill nozzle...must be a fuel return from the pump or something like that. Anyway, it was in an area where it experienced some rubbing and has developed a pinhole leak. Leak is more pronounced when the tank is full. I guess I'll just stop at the auto parts store and get a new length of hose whenever I get 'rountoit.
r
/ Hitting all the common BX problems #10
mine seems to be driping on the back side of the left rear tire
/ Hitting all the common BX problems #11
That's where mine seems to be leaking. I called the dealer about it and what he told me was that the fuel sending unit has sealing problems. When its in the shop I will also ask about the air breather bracket. Mine is out on warranty next month.
Dave
The early BXs leak fuel down onto the left tire when full. The dealer has some type of fix. I think it's coming out around the fuel level sending unit. Fixed under warranty for me.
- P
/ Hitting all the common BX problems #13
</font><font color="blue" class="small">( The early BXs leak fuel down onto the left tire when full. The dealer has some type of fix. I think it's coming out around the fuel level sending unit. Fixed under warranty for me.
- P )</font>
Same here! It did seem to leak more when really full, too.
/ Hitting all the common BX problems #14
I think kubota is a fine machine but again I think all tractors are good it's simply a matter of individual choice. This being said I cant help but wonder if kubota thinks that they built a good reputation over the years in building fine tractors and that they can somehow afford these little problems. Maybe I missed something here but should there be nothing less than a recall to fix these problem. cag
Agreed, would be nice if they just stepped-up and fixed all the known problems at once without multiple trips back to the dealer. BTW - The new air filter bracket is much sturdier than the original. Have not tried out the tractor to see if they got the HST pedal working right, sure seemed tight to me just putting the machine into the garage right from the truck. I'm guessing cleaning the pivot is not enough to fix this problem.
Now that I'm closing in on 300 hours, I'm just waiting for the steering to go... don't know if I have one of the 'rusty tubes' or not.
- Patrick
/ Hitting all the common BX problems #16
on the hst pedal, did they put in new cradle bearings, that is what they had to do to mine to fix it........with only 25 hours on it.
/ Hitting all the common BX problems #17
My throttle on the Gravely wouldn't stay at full. I fixed this by using one of those exercise straps in a loop like a rubber band to keep it fully open. It's easy enough to remove the loop to go down to idle.
Tried rubber bands initially. They kept breaking. My exercise strap loop hasn't broken yet.
Ralph
/ Hitting all the common BX problems #18
Ralph...... when are you going to retire that dinosaur Gravely and get the BX that you have been lusting for? If you wait too long, the BX is going to be like your Gravely, no longer made and everyone here will be talking about the next generation of Kubota's. /forums/images/graemlins/grin.gif
/ Hitting all the common BX problems #19
Mine leaked also from the sending unit. Mine was out of warranty, so I fixed myself. Kubota has a kit # K2561-96140 that replaces some of the parts on the sending unit. Basically, the old unit just set on a seal into a hole into the top of the tank. I don't know what engineer designed this, but obviously it was very poor design. The new kit comes with locking tabs on the attaching bolts that grip to the inside of the tank to seal it against the rubber seal. You remove the ROPS and left fender. The new locking tabs have a flat blad screw head that you turn to lock them with. I think two of these were under the ROPS mounting plate and tough to get to. Definitely allot yourself some time to complete the job.
Kit cost me $16.65.
/ Hitting all the common BX problems #20
I just don't understand why this wouldn't be repaired under a "extended" warranty situation because there is a liability issue here. Leaking fuel is definitely a responsibility of Kubota to repair if it is a result of a design failure. I understand that a manufacturer doesn't have a responsibility to make upgrades to older equipment just to make it better, but if it is a defect that effects safety or or environmental issues, I believe that they are responsible for those corrections. I know that they certainly would be if it was an automobile.
JOHN DEERE 11 SHANK CHISEL PLOW (A63291)
JOHN DEERE 11...
2004 John Deere 544J Articulated Wheel Loader (A61572)
2004 John Deere...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
Caterpillar Specification Manuals Vol. 3 Books 1 and 2 (A63117)
Caterpillar...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
