Hirschmann Connector
/ Hirschmann Connector #1
MikeyB
Parker,CO
JD 3320
Hi all,
I have ordered an electric selector valve from Surplus Center:
https://www.surpluscenter.com/item.asp?item=9-7852&catname=hydraulic
and it says it uses a Hirschmann connector for the electrical portion to the
solenoid valve:
https://www.surpluscenter.com/item.asp?catname=hydraulic&item=11-2457
Is anyone familiar with this type of connector? I don't know if the wire goes in the top (with hole) or the side with the threaded plug, or how many wires go into the connector. One or two, meaning I would need to order two of these things to make the connections to the solenoid. If anyone is familiar with how these connectors work I am all ears.
Thanks for any info,
Mike
/ Hirschmann Connector #2
You will only need one. The wire goes through the compression "nut" on the end, then the nut can be tightened to make a weather resistant seal. You should use a round jacketed wire (like a extension cord) for a good seal. 18/2 SO cord would be perfect-and is available at Home Cheapot or Lowe's.
Thanks Kenny D. I was hoping you would know how this thing works. My next question is how are the connections made with the wire/cable that I insert
thru the compression nut? I am guessing the bottom of the plug pulls out and you make the connections and then reinsert. I was a little confused when looking at the SurplusCenter pdf catalog as it says two are required for each solenoid?!
Thanks,
Mike
/ Hirschmann Connector #5
Thanks,
Mike
You only need one since this is a diverter valve-there is only one solenoid. If it was a regular solenoid valve-then you would need two. The hole in the top is for a screw to hold it on the valve, I tried to find instruction online but could not...You can handle it:thumbsup:
Thanks for your help!
Regards,
Mike
2016 Isuzu NPR 20ft Box Truck (A64556)
2016 Isuzu NPR...
2014 Kenworth T400 T/A Kill Truck (A64194)
2014 Kenworth T400...
Iranch High-End Tricycle (A64119)
Iranch High-End...
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
2009 8 Mil BTU Tri-Axle Hot Oil Trailer (A64194)
2009 8 Mil BTU...
