Hirschmann Connector
/ Hirschmann Connector #1
MikeyB
Parker,CO
JD 3320
Hi all,
I have ordered an electric selector valve from Surplus Center:
https://www.surpluscenter.com/item.asp?item=9-7852&catname=hydraulic
and it says it uses a Hirschmann connector for the electrical portion to the
solenoid valve:
https://www.surpluscenter.com/item.asp?catname=hydraulic&item=11-2457
Is anyone familiar with this type of connector? I don't know if the wire goes in the top (with hole) or the side with the threaded plug, or how many wires go into the connector. One or two, meaning I would need to order two of these things to make the connections to the solenoid. If anyone is familiar with how these connectors work I am all ears.
Thanks for any info,
Mike
/ Hirschmann Connector #2
You will only need one. The wire goes through the compression "nut" on the end, then the nut can be tightened to make a weather resistant seal. You should use a round jacketed wire (like a extension cord) for a good seal. 18/2 SO cord would be perfect-and is available at Home Cheapot or Lowe's.
Thanks Kenny D. I was hoping you would know how this thing works. My next question is how are the connections made with the wire/cable that I insert
thru the compression nut? I am guessing the bottom of the plug pulls out and you make the connections and then reinsert. I was a little confused when looking at the SurplusCenter pdf catalog as it says two are required for each solenoid?!
Thanks,
Mike
/ Hirschmann Connector #5
Thanks,
Mike
You only need one since this is a diverter valve-there is only one solenoid. If it was a regular solenoid valve-then you would need two. The hole in the top is for a screw to hold it on the valve, I tried to find instruction online but could not...You can handle it:thumbsup:
Thanks for your help!
Regards,
Mike
Sunflower Yard Art (A64557)
Sunflower Yard Art...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64278)
2023 JOHN DEERE...
UNUSED FUTURE MINI EXCAVATOR HYD QUICK COUPLER (A65055)
UNUSED FUTURE MINI...
2149 (A65055)
2149 (A65055)
2025 58in Hydraulic Trencher Skid Steer Attachment (A64553)
2025 58in...
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
