Hinomoto E264 front axle
/ Hinomoto E264 front axle #1
Jake1883
I need bearings for for my e264 in the front spindle. It is a large bearing that carries all of the weight. Both of my bearings are out and it makes it almost impossible to steer. I was hoping someone might know what Massey tractor had the same front end. Iwould appreciate any help. Thanks Jake
/ Hinomoto E264 front axle #2
If it's just the bearings that are out and the spidles aren't galled or otherwise destroyed can't you just replace the bearings? If you pull the axle apart the bearings almosy always have the manufacturer and bearing number on them.
Using that info you can usually cross reference it to a Timken, FAG, NSK, etc...
EDIT:
I did a quick google search and found this....
http://www.tractorbynet.com/forums/grey-market-tractors/84547-new-club-hinomoto-e264.html
Buppy69 said...
" I also have a 264 that I installed power steering on. It has a factory loader. For external engine parts it crosses reasonably to a Massey 1035. The front axle is from a Massey 220-4."
/ Hinomoto E264 front axle #3
I had to replace mine. The races and seals came from MF. I got the ball bearings (3/16") from our local bearing house.
Eugene
Thanks for the info. I ordered the bearings from MF for the MF model 220-4. I sure appreciate the help. Thanks again, Jake
/ Hinomoto E264 front axle #5
Good luck. But according to my parts books they are not the same bearing. The E264 bearing doesn't cross to any Agco models.
/ Hinomoto E264 front axle #6
So how did this turn out? Were the bearings the correct size?
Every thing worked great and the parts were easy to get and they are reasonably priced. The MF parts were about half the price of Hino parts.
2014 John Deere 1025R (A64126)
2014 John Deere...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
213086 (A64276)
213086 (A64276)
2007 Ford F53 Landau 3645DS 36ft. Class A Motorhome (A61574)
2007 Ford F53...
2015 Chrysler 300 Sedan (A61574)
2015 Chrysler 300...
