Hinomoto E264 front axle
/ Hinomoto E264 front axle #1
Jake1883
I need bearings for for my e264 in the front spindle. It is a large bearing that carries all of the weight. Both of my bearings are out and it makes it almost impossible to steer. I was hoping someone might know what Massey tractor had the same front end. Iwould appreciate any help. Thanks Jake
/ Hinomoto E264 front axle #2
If it's just the bearings that are out and the spidles aren't galled or otherwise destroyed can't you just replace the bearings? If you pull the axle apart the bearings almosy always have the manufacturer and bearing number on them.
Using that info you can usually cross reference it to a Timken, FAG, NSK, etc...
EDIT:
I did a quick google search and found this....
http://www.tractorbynet.com/forums/grey-market-tractors/84547-new-club-hinomoto-e264.html
Buppy69 said...
" I also have a 264 that I installed power steering on. It has a factory loader. For external engine parts it crosses reasonably to a Massey 1035. The front axle is from a Massey 220-4."
/ Hinomoto E264 front axle #3
I had to replace mine. The races and seals came from MF. I got the ball bearings (3/16") from our local bearing house.
Eugene
Thanks for the info. I ordered the bearings from MF for the MF model 220-4. I sure appreciate the help. Thanks again, Jake
/ Hinomoto E264 front axle #5
Good luck. But according to my parts books they are not the same bearing. The E264 bearing doesn't cross to any Agco models.
/ Hinomoto E264 front axle #6
So how did this turn out? Were the bearings the correct size?
Every thing worked great and the parts were easy to get and they are reasonably priced. The MF parts were about half the price of Hino parts.
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2018 FORD F-350 SUPER DUTY (A65643)
2018 FORD F-350...
SANY SY35U EXCAVATOR (A63276)
SANY SY35U...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
CAT CB34 (A60462)
CAT CB34 (A60462)
