Hiab hydraulics Question
/ Hiab hydraulics Question
(making this searchable so other looking might find the info) Found some info via a mate for the hiab
The minimum spec for the hiab 650 is 2000 PSI and 50 litres per minute or 13 gpm gallons per minute
Finally got hold of him, he got the numbers from another guy who works at a truck wreckers. I will try to follow it up
/ Hiab hydraulics Question #14
Usually knuckle booms are high pressure low volume. The older ones would be around 2500psi. The flow effects speed not how much it will lift. Slower may not be a bad thing with these units. Hiab crane out of Florida helped me with some info on the jack legs. PH# 407 246 1597 the rest I replaced with standard parts. CJ
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
1997 Dorsey 45' Aluminum Citrus Trailer (A60462)
1997 Dorsey 45'...
