Hiab hydraulics Question
/ Hiab hydraulics Question #1
Timbersawz
Under here over there
Holder a60
Im looking at a 650aw hiab to mount to a tractor. Not going to be easy, but thats the fun of it right?
I have been trying to work out the hydraulic specs the crane requires to run properly as its going to require running a pump off my machines front PTO (tractor only runs 10.5 g/m at 1755 lbs). But I havent been able to find them through searching.
Im hoping someone on here has some idea on how much the little lifter needs to get it up.
/ Hiab hydraulics Question #3
The last unit I worked on the relief was set at 2400psi. I had to get parts out of Florida and hope to never see one again.CJ
Thank you very very very much! I have been searching all over the net, trying to get specs on truck pto pumps etc. Awesome! (I should have mentioned its a 1000rpm pto but have found a simular unit)
Would running a higher GPM be a problem?
So what was the problem with the 650?
/ Hiab hydraulics Question #5
Why can't you use tractor hyd? You said 10.5 GPM. Is 1755 your tractor pressure. What kind of flow does the lift require.
How about this pump. 1000 PTO rpm, 13.5 GPM at 2000 psi.
3.6 CU IN PRINCE HC-PTO-8AC PTO PUMP 1000 RPM CI
It makes no sense to purchase a large pump for a small GPM implement.
/ Hiab hydraulics Question #6
Hi from the uk guys
I have a Viper HLK 60 crane on my Leyland 272 running directly of the tractor hyd system at 1950psi on tick-over around 2000 psi at 1/4 throttle the crane works really well
With this setup lifting about a ton close in on 3/4 rev's
It will lift a bulk bag of logs at full reach (5 mtr ) on tick-over.
/ Hiab hydraulics Question #7
I would use the tractors hydraulics. It will run it fine. Cj
/ Hiab hydraulics Question #8
BTW you will most likely need to reduce the flow on the slew pipes though as it really fly's round especially if you are using the other controls.
/ Hiab hydraulics Question #9
What flow rate in GPM is the Hiab designed for.
(making this searchable so other looking might find the info) Found some info via a mate for the hiab
The minimum spec for the hiab 650 is 2000 PSI and 50 litres per minute or 13 gpm gallons per minute
Finally got hold of him, he got the numbers from another guy who works at a truck wreckers. I will try to follow it up
/ Hiab hydraulics Question #14
Usually knuckle booms are high pressure low volume. The older ones would be around 2500psi. The flow effects speed not how much it will lift. Slower may not be a bad thing with these units. Hiab crane out of Florida helped me with some info on the jack legs. PH# 407 246 1597 the rest I replaced with standard parts. CJ
