Tires Help
estewart
spartanburg, sc
Hinomoto E2304
My husband is out of the country. We have a hinomoto E2304 series tractor. I need to put air in the tires, but I do not have a manual and the writing on the tires is written in Japenese. Can someone please tell me what tire pressure is recommended for the front and rear tires?
I am not to fussy with my tires on my kubota. Somewhere between 10 to 15 psi usually works. If I am doing lots of loader work I usually up the front pressure a little. Do you know if your tires are loaded? If they are put the valve stems at the top of the wheel {12 oclock position} before you put the pressure gauge on it. That will keep the fluid inside the tire from getting into the gauge. If you don't know if the tires are loaded put the valve stems at the top anyway.
2010 Mac Trailers Walking Floor Trailer (A64556)
2010 Mac Trailers...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
Heavy Duty Booster Cables (A64557)
Heavy Duty Booster...
CATERPILLAR D6N LGP HI-TRACK CRAWLER DOZER (A65053)
CATERPILLAR D6N...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2013 International DuraStar 4300 S/A Dump Truck (A64556)
2013 International...
