help
david bollman
cub cadet lt1045 2009
took off the deck on mower did not know the pto clutch was attached to a rod which i disconnected to remove deck. started cut ~100ft blew fuse put 30 amp fuse and cut ~100 ft blew fuse again. then i realized my mistake hooked up rod noticed wire coating cut but not wires. now clutch wont turn blades. it has 175-200 amp reading and on bench test it clicks when attached to 12volt battery. what to do? 2009 cub cadet lt 1045 shouls i change drive belt now
thanks, davidb
KBH Tender (A63688)
KBH Tender (A63688)
2014 Hagie DTS10 Sprayer (A63111)
2014 Hagie DTS10...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
208316 (A58375)
208316 (A58375)
