help with repeat blown headlights
/ help with repeat blown headlights #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
My wife has a 2002 Honda CRV - Since we have owned the vehicle we have had to replace the headlamp bulb(s) about every 3 month or so. She does not run the headlights everyday, and it does not have daytime running lights.
The low beam side is the only side that is out. Its almost like clockwork once you need to change one side within several weeks you will be replacing the other side.. Then you are good to go for the next few months.
Any suggestions on why this is happening?
Brian
/ help with repeat blown headlights #2
Are they the same manufacture, like GE etc.? and do you have a loose connection to the bulb?
/ help with repeat blown headlights #3
What is the voltage at the battery with the engine at a normal driving RPM, say between 2000-3000 RPM? Excessive voltage output from the alternator could shorten bulb life, as well as damage the battery and other electronics on the vehicle. Any unusual buzzing or noise on the radio?
/ help with repeat blown headlights #4
I was losing lights very quickly in my truck and the lamp was cracked or broken. Then I noticed condensation inside the cover. Moisture was building up and dripping down on the hot lamp. I dried out the light and got a good seal on the bulb and it hasn't been a problem since...knock on wood.
/ help with repeat blown headlights #5
If they are halogen bulbs, I have been told that you cannot handle them with your fingers. Use a clean cloth.
/ help with repeat blown headlights #6
Happened to my mustang. It was when the hooked up the automatic start, and they crossed something up. I was driving home and put my lows on and they both went. i only had highs. I took the back roads home but it took a while before the stealership was able to fix it.
good luck if its this.
I ended up telling ford to make sure they crossed the wire so that it would burn the car up and i would not have to ever deal with them again.
/ help with repeat blown headlights #7
It's always a good idea to replace them in pairs. Chevy trucks in my experience have been the worst about it with their daytime running lights. If any of you have one and replaced one of the bulbs you probably noticed how burned the connector was. Chances are the other one was just as bad if not worse. I'm no electrician but I was a mechanic quite a while and I had to learn this the hard way about replacing in pairs.
/ help with repeat blown headlights #8
Fingerprints will create hot spots and dramatically shorten the life.
/ help with repeat blown headlights #9
thatguy
My previous employer made sealed beam lamps
Look at the guage of the filimant betwen different brands the heavier ones ususlly last longer.
The other thingthat beats them up is rough roads when they are hot the become more fragle.
Usually motorcycle lamps are a heavier duty than standard automotive ones, mabe they would last longer.
Try and avoid touching the lamp glass if it is a cartrage one, oil on your hands creates a hot spot on lamp = earlier failure clean it off with denatured aholchol
tommu56
/ help with repeat blown headlights #10
As allready stated , have the voltage checked . It should be no higher than 14.2 volts at high idle with the lights on . Use good quality 55w/70w bulbs , Hella etc . In regard to fingerprints on halogen bulbs , the reason is that when the bulb heats up the oily fingerprints emit smoke which dulls the reflector in the headlight over time .
Thanks for all the help.. I am pretty sure i shortened the life of the first couple lights by handling them, but since then I go to great lengths not to touch the bulb at all.. I have even used latex gloves in case I do touch the bulb. I havent tried cleaning them them denatured alcohol though.
FWIW - The bulbs are #9003 Halogens (NOT sealed beams)
I havent seen any condensation in the headlight, but will look closer. I will also check the voltgage and see what I am getting..
thanks for the help
Brian
/ help with repeat blown headlights #12
All good tips so far...
I've also noticed that country of origin sometimes matters... USA and germany being the best, china the worst. Look on the bulb itself, not the package.
/ help with repeat blown headlights #13
After WTA's tip about replacing in pairs, I did so on the wife's 2004 Beetle front signal lights. Old bulbs were still good but left side flashed fast. I had replaced the left only and worked OK for about one day. After replacing both, we have not had a problem for over a week.
2820 (A62131)
2820 (A62131)
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
10 Lug Wheels Full Set (A57453)
10 Lug Wheels Full...
2016 John Deere Z535M Zero Turn (A63116)
2016 John Deere...
2022 Kubota 74in. Hydraulic Dual Cylinder Grapple Skid Steer Attachment (A61567)
2022 Kubota 74in...
