Help with non working gauges
/ Help with non working gauges #1
jeephound1
Tyler, Tx
2009 cub cadet ex3200
I'm new to the forum, so hope I get this correct.
I just purchased a 2009 Cub Cadet Yanmar EX3200 tractor and my fuel gauge and Temp gauge are dead. All warning lights, tach, hour meter, headlights and dash lights work perfect. Any help or ideas? Thank you
Thanks, I did check all fuses and they're good. Each gauge has 3 wires on back of them, red, black, yellow. With a test light bought gauges red wire has power.
/ Help with non working gauges #4
I'm sure you have probably checked the sensors making sure the wires are connected to them?
yes sir, even tried grounding the positive wire on the fuel sending unit. Nothing happened with the needle on the gauge. I haven't pulled the sending unit from the tank.
/ Help with non working gauges #6
Do you have a wiring diagram? I am wondering if one of the 3 wires going to the gauges is for illumination?
I bet the yellow one is lights, I'll check it.
/ Help with non working gauges #8
I would guess yellow is ground, black and red hot. Sure nuff a guess.
Fuel gauge worked a couple days off and on, but not the temp. Could it be a ground?
/ Help with non working gauges #10
Short answer, but yes it could be ground.
/ Help with non working gauges #11
How about it jeephound, what did you discover? I find myself in the same situation.
/ Help with non working gauges #12
Maybe start a new post, This is now a zombie post from 2014. I don't even recognize that guys name and i have been here way before that post was made so that tells me he has not been on here much and has probably left the forum totally.
/ Help with non working gauges #13
Jeephound, that was the last post that guy ever made. 5+ years ago.
I suggest repeat your inquiry in the Yanmar (New) group. That's where you will find other EX-3200 owners.
Yanmar departed the US market for a couple of decades then returned. So today there are two nearly-unrelated generations of US Yanmars - and the active dealers of the present generation don't know or care about the ones sold likely before they were born.
This classic Yanmars group we're in is where owners of the classics gather to share expertise.
/ Help with non working gauges #14
Any luck? I went to start up my ex3200 and am having the same problem I have posted in the New Yanmar forum as well.
/ Help with non working gauges #15
bump did anyone find out why the temp gauges not working. Mine just stopped.
/ Help with non working gauges #18
/ Help with non working gauges #19
Hi everyone, i have the same issue with the temp and fuel gauge on Cub Cadet Yanmar EX3200, did anyone ever get this resolved or insight.
very frustrating mine works sometimes and sometimes not. they are both affected
/ Help with non working gauges #20
Nighthawk I suggest repeat your inquiry in the Yanmar (New) group. That's where you will find other EX-3200 owners.
This classic Yanmars group we're in is where owners of the old classics gather to share expertise.
