Help with MF175 purchase
/ Help with MF175 purchase #1
Sebalj
N/A
MF175
I'm a newby and looking for some advice on an MF175 I'm looking to buy for work around our 23 acre hobby farm. I've read through the MF threads, but couldn't find anything specific to the 175, so if any of you have comments or suggestions on anything I'm about to say, please do so. This is a long post, so grab a coffee and amuse yourself at my ignorance. The only knowledge I have of tractors is a couple of hours on my neighbour's using a post hole auger, and what I've been able to find online. I apologize for the length, but I wanted to be thorough. I'll be using the tractor for loading and pulling a manure spreader, auguring post holes, and a myriad of other chores including snow clearing in the winter. We live in Eastern Ontario, Canada. We'd like to eventually harvest our own hay, so mowing, raking and baling about 10 acres for our 2 horses will be on the do list in the near future. I also need to put a new road back to the barn, and bring in sand for a riding arena.
The tractor is a 1971 MF 175, with the Perkins A4 236 engine, an MF Model 200 loader with down pressure and a very solid bucket, a Whistler Cutter Model# W5MO (bush hog style) attachment and a George White & Sons Model# 90717, 72 snow blower with hydraulic chute. It has 6381 hours, with a new clutch at aprox 6000 hours. There's a block heater (critical for -20C starts, I would think). The fuel gauge isn't working, but all others are OK. All the lights work. There are 2 rear hydraulic lines for the blower chute. The owner is asking $8000.00 Canadian ($6900 US) for the works. I have a neighbour who is a diesel mechanic joining me on the second look at it to make sure everything is sound, but I thought I'd ask if there's anything in particular we should look for with this tractor? Now that the clutch has been replaced, what will likely be the next major repair?
It looks like it has been well cared for, with some new hydraulic hoses to the loader, decent tin, new 26 rear tires (with calcium), rebuilt front cylinder injector. I looked all around it for leaks but couldn't find anything other than sweating around seals. Oil and transmission fluid looked clear. It shifted easily, however, I had difficulty finding the S (neutral?) location on the High/Low range shifter to get it started. The owner said the smaller rear tires (26 vs. 28 inch) where recommended to him in order for the rear end to sit a little lower to help offset heavy loads in the bucket.
Shifting the PTO lever from hydraulic drive to ground drive was difficult, because the lever was loose. I couldn't tell if the looseness was the lever connection to the shaft that went into the transmission, or something internal that wasn't engaging properly. I may be confusing the terms here, but there were 3 positions for the PTO lever. The owner explained that the PTO could also be driven in the ground position (lever fully forward) where the PTO speed was governed by the speed of the wheels. The current owner split and re-assembled the tractor himself, but had the clutch rebuilt at the dealership. Could this be a simple case of the new clutch needing adjustment, or something worse?
I welcome any advice on specific things to look for during my second visit to the tractor.
Thanks for your help.
/ Help with MF175 purchase #2
Hmmm, you just described an almost 40 year old tractor that sounds to be in better shape than my two 165's. The ground drive pto is sometimes a little tricky to get in on the one of my 165 that has it. The tractor must have a 2 stage clutch if you have ground drive also. I don't think I'd worry about that. Does it have a Multi-Power transmission. If so there would be a few more things to look at. Seeing that you didn't mention it, I'll asume not. It's a pretty simple tractor, it should suit you well.
26" rubber seems small to me, but that really isn't a big deal. I'm used to 38" rims. Sounds like a solid machine to me.
Thanks MFRED,
Appreciate the sanity check on the tractors condition. The last thing I need is another make work project.
The transmission had two power ranges, Low and High, so I'm assuming that it's NOT a Multi-Power transmission. I read another post in a different forum on the Ground setting for the PTO. They said the ground setting isn't of much use anymore with newer implements that do not depend on ground speeds for operation. So, I likely won't have to use it. However that depends on the definition of "newer".
MFRED,
I went and bought the thing. Talked him down a little in price based on some concerns.
Thanks again for your help.
/ Help with MF175 purchase #5
Good for you. Sounds like a good deal, even without talking the guy down. It should be a good tractor for you.
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
2014 Ford Escape SE SUV (A61569)
2014 Ford Escape...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
2016 Lincoln MKC SUV (A61569)
2016 Lincoln MKC...
2017 Chevrolet Cruze Sedan (A61569)
2017 Chevrolet...
Welcome to the Farm Metal Decorative Sign (A61569)
Welcome to the...
